2.0 to 2.2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2004, 09:36 PM   #1 (permalink)
View mr2freak's Photo Gallery
2.0 to 2.2
would it be safe for the engine(3s-gte) get get bored out to 2.2? is there any aftermarket support for a boosted 2.2 3s-gte? im think low compression pistons, tie rods? i guess crank shaft wouldnt be different from an aftermarket crank for a 2.0 3s-gte, right?
Cause i was thinking, it would raise torque and hp easily.
but i got warned against boring out turbo blocks.
Any toughts on this?Anyone read something about it or know someone who did it?
Women... can't live with 'em, can't shoot 'em - 87camry5speed
Seriously... PETA is a militant group. They suck in genuinely concerned people, and spit out hitler faeries - Toysrme
mr2freak is offline   Reply With Quote
Old 01-12-2004, 09:44 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
jun makes a stroker kit for 3SGTEs.....also i think extreme boost is working on making a kit also....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 01-12-2004, 09:45 PM   #3 (permalink)
Fist of the North Star
View Komodo's Photo Gallery
Overbore to 2.2 not a good idea.
On the other hand there are several companys that
have 3sgte 2.2 stroker kits.
Basically a different crank,con-rods and pistons etc.
Some people even peice togther their own using
a 5sfe crank I believe.
Komodo is offline   Reply With Quote
Old 01-16-2004, 03:10 PM   #4 (permalink)
and would that be safe pushing around 18-20 psi?
Old 01-16-2004, 05:15 PM   #5 (permalink)
supposedly the 5sfe rank is strong enough to handle some
serious boost.
The stroker kits from the east are expensive about
$3000 usd.
I don't rember the exact web page but there is a guy in the
states selling stroker kits that include a 5sfe crank, con rods,
and pistons.
I'll do a goolge and see if I can find it later.
These kits were alot cheaper.
Old 01-16-2004, 09:48 PM   #6 (permalink)
i'll be running that much boost on my stock motor.....well....with race fuel at the track though......i dont think i wanna boost that much on 94 pump......
91 mr2..07 335i..
Old 01-20-2004, 04:31 PM   #7 (permalink)
naw id wanna be pushing 12-13 psi on the streets with a scramble of about 16psi and around 20 at the trackon race gas.I think ill just use forged pistons and con rods, balanced crank, blue print engine and port and polish head.
Hey Q, how much HP do you think youll be making at the wheels
Old 01-20-2004, 05:57 PM   #8 (permalink)
i'm around the 300rwhp range with my current setup.....
91 mr2..07 335i..
Old 01-24-2004, 07:10 PM   #9 (permalink)
http://www.cj-motorsports.com/mr2parts.htm
These guys have a pretty good loking stroker kit put together.
Old 02-24-2004, 08:27 AM   #10 (permalink)
View JspecGTS's Photo Gallery
6deep.com has a stroker kit from a 2 to 2.2 but it cost at least 2 grand and that not including the pistons you have to buy for it. good luck
JspecGTS is offline   Reply With Quote
Old 07-12-2004, 09:00 PM   #11 (permalink)
View mR2dRagsTer's Photo Gallery
stroker kit??? are you serious. do you know how bad that is for an engine? i say over bore the engine. cause with a stroker kit you are lowering your rod ratio, which inturn means you have to lower your redline, if you dont want to sideload your cylinder walls. i mean mr2 have what about a 1.56 rod ratio which is pretty low already so i wouldnt suggest lowering any further. by the way an ideal rod ratio is 1.75:1
mR2dRagsTer is offline   Reply With Quote
Old 07-12-2004, 09:08 PM   #12 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
*I am running 23 psi on the stock engine.
As for getting to 2.2 liters, the best route to go is to use the 5SFE block along with the 3SGTE head.
That is what Mike Colon is running in his street driven low 10 sec car ... that should be 9s by the end of the summer.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 07-12-2004, 11:08 PM   #13 (permalink)
Gameroom cash: $147537
Yea, why fool around with the 2.0 block when you can pick up a 2.2 5S block for cheap?
Old 07-13-2004, 07:12 PM   #14 (permalink)
this might sound stupid but bear with me, im still learning toyota, what is a 5SFE engine? what car does it come from?
Old 07-13-2004, 07:51 PM   #15 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
5SFE comes from everything: Camry, Celica, NA MR2 and I think Solara.
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
