Originally Posted by redmistertwo
thanks for the post mr2 bad but would i really be able to install the antenna, seeing as how it has to be routed through to the deck?
You should be able to use the antenna cable behind the deck just like it is. I t should lead to the power antenna.
also theres some random parts that were left in the track when the antenna snapped off. does thta matter?
Those parts need to be removed and the new unit put in it's place.
p.s. why did the title of my post turn bold with a blue fast forward symbol next to it?
It appears when there are additional posts to your thread.
If you click on that, it will take you to the last unread post.
