help mr2 blogging down - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2009, 03:32 PM   #1 (permalink)
View 91mr2ky's Photo Gallery
new here to the forum awsomee site guys
well here is my problem i own a 91 mr2 N/A
i ended up gettin a jdm intake manifold and 15lb injectors well i put everything on and it wouldnt work i changed the fuel rail and blocked the egr valve that didnt work so i went back to the stock injectors and stock manifold and its still blogging
it runs fine but as soon as i give it some gas it blogs down i changed the spark plugs checked the disturbertor and adjusted the timing even re-adjusted the tps sensor and still nothing still blogging down after i give it some gas
it will go up to 2,000 rpms even 3,000rpms sometimes
what could be the reason please help thanks call me at 2709918950 i would really appreciate it thanks
91mr2ky is offline   Reply With Quote
Old 03-06-2009, 10:18 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Was everything working ok before you installed new injectors?
The Jedi Speeder at CarDomain
Old 03-06-2009, 12:25 PM   #3 (permalink)
yes it worked perfectly fine i put the stock injectors back on there and manifold changed the o2 sensor also used fuel injector cleaner and still nothing
i think it mite be the vsv sensors
Old 03-06-2009, 12:44 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Sounds like something didn't get put back corectly/missed. Vacuum line?
Why did you try to put bigger injectors? How were you gonna increase the air intake to maintaine proper A/F ratio?
Old 03-06-2009, 04:56 PM   #5 (permalink)
well i have a bigger intake manifold also thats way bigger than the stock one but it still did the same thing
the vaccum lines thats where i got confused but i think i figured it out where it goes using the sticker
Old 03-06-2009, 04:57 PM   #6 (permalink)
i also got a intake on it that goes all the way down to the vent
