5sfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2009, 06:25 PM   #1 (permalink)
Popping flames
Plbiohazard's Avatar
View Plbiohazard's Photo Gallery
5sfe
Couple questions for the mr2 guys. Is there a difference between camrys 5sfe and mr2s? How much psi can the 5sfe withstand on stock internals and where can i buy internals for it?
Plbiohazard is offline   Reply With Quote
Old 03-23-2009, 06:55 PM   #2 (permalink)
Bdub215's Avatar
Gameroom cash: $317765
View Bdub215's Photo Gallery
How to Turbo the Camry - 5s-fTe tips and information suggest that as a start and posing this question in the camry gen 3 & 4 section.
93 Lexus ES300 5spd I/E URSB
Bdub215 is online now   Reply With Quote
Old 03-23-2009, 08:05 PM   #3 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
The 5S block is a beast and can take just about anything you can throw at it. Ditto the camshaft. I'm not sure about the stock rods and pistons.
There are some differences between MR2 and Camry 5SFEs but whether or not they will affect you depends on your goal.
What do you have now and what are you going to try to do?
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 03-24-2009, 07:57 PM   #4 (permalink)
Popping flames
Im trying to throw on a turbo on my camrys 5sfe but I needed to know if i can use the same parts as the mr2 since there both 5sfe's
Old 03-27-2009, 12:37 PM   #5 (permalink)
View 89ma70's Photo Gallery
a stock 5sfe can hold about 8-10psi and maybe more on a good tune. I have been lookin at internals on ebay and such because I was thinking about doin a 5sfte.
89ma70 is offline   Reply With Quote
Old 03-27-2009, 12:47 PM   #6 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Yeah, you can use most of the same parts as the MR2s. You'll be in luck because you have a lot more room in your engine bay.
Old 03-29-2009, 02:22 PM   #7 (permalink)
Popping flames
Great =) just one more question are the transmissions the same to? and can it handle the turbo?
Old 03-29-2009, 03:51 PM   #8 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
The transmissions are almost the same. As I recall, the only difference is the location of the linkage mounting. FF have it on the rear of the tranny because the driver sits behind the engine; in a MR layout the linkage is in front because that's where the driver sits. This can be modified so you can use either type of tranny on either layout.
The 5SFE transmission probably cannot handle turbo power levels, at least not for too long. Look for a E153 transmission out of the turbo MR2s. You'll need to modify the linkage mount like I mentioned before.
Old 03-30-2009, 12:57 PM   #9 (permalink)
View concealer404's Photo Gallery
Originally Posted by Ghostyman View Post
The transmissions are almost the same. As I recall, the only difference is the location of the linkage mounting. FF have it on the rear of the tranny because the driver sits behind the engine; in a MR layour the linkage is in front because that's where the driver sits. This can be modified so you can use either type of tranny on either layout.
The "break point" of the S53 transmission seems to be around 300whp. I'd bet the motor blows up before that. :P
Depending on what year camry, the 5sfe will be different. Does it really make a difference? No. But later camrys had slightly different displacement.
1993 Celica GT Coupe (sold w/ 218k miles)
1992 Celica GT Hatch (The new $600 hotness.)
1993 Escort GT ( i have a thing for GTs.) POWERED BY MAZDA B-SERIES
concealer404 is offline   Reply With Quote
Old 04-03-2009, 07:12 PM   #10 (permalink)
View 1badtwo's Photo Gallery
theres a few 5sfe turbo MR2 guys, but not many, its much easier to go 3sgte or v6 in the case of the mr2
1badtwo is offline   Reply With Quote
Old 04-04-2009, 01:15 AM   #11 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
You could build an economical 5SFTE for the price of a cheap 3SGTE but you really limit your room to grow. If you think you'll be satisfied with 200whp, the 5SFTE seems like a decent choice. Otherwise you want to buy and start modding a 3SGTE (or a V6 as mentioned above... but anybody who should be doing a V6 swap will suggest it themselves rather than have it suggested to them).
