Belts Squealing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2009, 12:13 PM   #1 (permalink)
Shadow54's Avatar
View Shadow54's Photo Gallery
Canada Belts Squealing
Hey guys my 86 MR2 is having some problems, I know I need to replace the clutch and some of the belts are making noise. Does anyone know how I would go about adjusting them. Also the car will not start if the temperature is below 0 celcius. Any Ideas?
Shadow54 is offline   Reply With Quote
Old 03-27-2009, 03:13 PM   #2 (permalink)
View MR2Brock's Photo Gallery
As for belts, loosen the mounting bolts a little and then tighten belt with the tensioning bolt until belt is tight and then tighten mounting bolts. Common problem with alt belt.
As for cold start issue, begin by doing a simple tune up. New plugs, wires, cap, and rotor. Also run lower octane fuel. Would be a good time to change the fuel filter as well.
MR2Brock is offline   Reply With Quote
