Instrument Cluster - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2009, 11:25 PM   #1 (permalink)
View ralpher's Photo Gallery
2nd Generation Instrument Cluster
my speedo dont work any more
what can i do to fix it? or will i have to replace it
its a 1991 mr2.
whats the red line on the 91 turbo engine?
i just swaped the engines and i was wondering if it would be the same
91 mr2 turbo
08 tacoma trd
ralpher is offline   Reply With Quote
Old 04-14-2009, 11:47 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Is this an NA to Turbo swap? Are you using a '93+ engine? If so... you probably need to buy all of the parts to convert your electronic tranny sensor to mechanical. If not.... I'd start with buying new speedo cables... and go from there.
Old 04-15-2009, 02:15 AM   #3 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Speedometer on 91 turbos is via a mechanical cable from the tranny to the cluster. The problem is somewhere between those three components (sender on the tranny, cable, or cluster). I haven't seen my MR2 for four months but I recall the redline being 6800 RPM.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 04-15-2009, 10:42 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Close Ben-Redline is 7000 RPM's
The Jedi Speeder at CarDomain
Old 04-15-2009, 03:20 PM   #5 (permalink)
yes it is a na to turbo swap.
so ur saying i need a new cluster??
91 mr2 turbo
08 tacoma trd
Old 04-15-2009, 03:22 PM   #6 (permalink)
its a 91 turbo swap, jdm
91 mr2 turbo
08 tacoma trd
Old 04-15-2009, 03:40 PM   #7 (permalink)
Piddy's Avatar
If your speedo worked before.... I would say it's the sensor on the tranny.
Old 04-15-2009, 03:42 PM   #8 (permalink)
it worked with the old na engine
91 mr2 turbo
08 tacoma trd
Old 04-15-2009, 05:44 PM   #9 (permalink)
Piddy's Avatar
New tranny.... new sensor.
Old 04-17-2009, 11:58 PM   #10 (permalink)
where is the sensor hook up on the trany
i looked for it but i cant find it
the tranny is a jdm does that make a difference?
91 mr2 turbo
08 tacoma trd
Old 04-18-2009, 12:27 AM   #11 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Sensor is the thing with the wires sticking out of the tranny just a little to the right of the red mount.
JDM shouldn't matter.
@mr2bad: see, I don't get to drive my mr2 and I start thining it can rev lower than it really can....
Old 04-18-2009, 12:36 AM   #12 (permalink)
i think 91 was cable driven speedo and
92+ the speedo was the electronic speedo
i got a 91 car and im guessing my trany is from 92+
is there any way i can get something to convert it to work or will i have to get a new cluster and wires?
91 mr2 turbo
08 tacoma trd
Old 04-18-2009, 12:56 AM   #13 (permalink)
i just found a converter that converts a electrnic signal into a mechanical signal
check it out
http://www.atrol.com/cablex.htm
91 mr2 turbo
08 tacoma trd
Old 04-18-2009, 01:16 AM   #14 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
The transmission is the same regardless if you have electronic or mechanical sender. They both screw into the same spot on the tranny. If you have a '91 cluster, you have a mechanical cable and should find a mechanical sender. They will be cheaper than the "Cable X" and probably more accurate.
Old 04-18-2009, 01:29 AM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I see... When do you think you'll be done?
