Fuel Pressure question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2004, 08:34 PM   #1 (permalink)
Tearin' Up The Streets
MR2QuiK's Avatar
View MR2QuiK's Photo Gallery
I raised my boost so i was thinking of raising my fuel pressure to balance it out. do you guys think its a good idea? what is the stock fuel pressure ? and is it worth it?
Depicted Motion MR2
MR2QuiK is offline   Reply With Quote
Old 01-26-2004, 09:10 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
The MR2 already raises FP for you.
Base idle FP is 36 psi ... as you increase boost, the the OEM FP regulator raises FP by 1 psi for each psi of boost added.
If you are on the stock turbo, you will never out run the fuel system.
If you have upgraded to a larger turbo and are running big boost (over 18 psi), you may want to buy an adjustable FPR so you can raise your base idle FP.
Base idle fp + boost should never exceed 65-70 psi.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 01-26-2004, 08:56 PM   #3 (permalink)
MR2QuiK's Avatar
thanks for your information
Depicted Motion MR2
Old 02-05-2004, 05:13 PM   #4 (permalink)
View Deuce_Bigalow's Photo Gallery
Is there an adjustable fuel pressure regulator that is rising rate? Like the OEM one? I need more fuel for my HP goals.
Any suggestions on what FPR to go with if I am just increasing the fuel pressure to increase the flow of my 440's?
Deuce_Bigalow is offline   Reply With Quote
