Fuel Injectors 87 MR2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2009, 06:29 AM   #1 (permalink)
View GeoffBooth's Photo Gallery
Just replaced the head gasket and now I seem to have 2 injectors not working. They may have been contaminated (dirt) while out of the car. Maybe broken wire in the loom. I'm going to check for risistance but does anyone have any ideas for a fix or further checks.
Geoff
GeoffBooth is offline   Reply With Quote
Old 05-22-2009, 02:51 PM   #2 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
If you apply voltage to the injector, they should click. I just tested this by touching the leads from a 12 VDC power source to the plug of a 5SFE injector I had sitting around. There is a noticeable "click" when it fires.
How have you diagnosed that two injectors aren't working?
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 05-22-2009, 07:09 PM   #3 (permalink)
Hi Ghosty, I've had it all apart, pistons out, replaced head gasket. Put it back yogether and it is missing.
Pulled #3 plug wire and no change. Spark and plug is good. Besides the injector wasnt ticking. Switched the injector with #1 then #1 and #3 wasnt working but like an ass I never checked #1 at the time I was messing with #3. Anyway the wiring harness is a bit brital and was bent out the way to be the head off. The injector plugs are a bit iffy. I just put power to a injector and it clicks like you said. Checked the risistance and thats good. cleaned the conector on #1 and held is on and it fires. Now I'm going to mess with #3.
Geoff
