Crash bolts are just necked down bolts that replace the upper bolts that attach the wheel knuckle/hub to the strut body. Since they are smaller in diameter on the shank of the bolt, this allows you to tilt the knuckle (changing camber) if the bolts are loosened. there is a limit to how much additional adjustment you can get from crash bolts. The stock bolts give you about 1 to 2 degrees of adjustment.
I think the camber kit linked to above is just crash bolts but I am not 100% sure on that.
________
CBulen
Project MV8R: 2nd Gen V8 MR2 engine swap
MV8R.com
