somethings wrong!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2004, 07:00 AM   #1 (permalink)
View gasman's Photo Gallery
Unhappy somethings wrong!!
i was crusing around town in my 1989 mr2 gt at night having a few races and stuff and all the time it boosted 8 psi them on my way home it wouldnt boost above 5 psi!
is some thing wrong?
or is this normal?
help
Brake-Down Shift-Turn
gasman is offline   Reply With Quote
Old 02-05-2004, 12:32 PM   #2 (permalink)
Tearin' Up The Streets
MR2QuiK's Avatar
View MR2QuiK's Photo Gallery
Thumbs up
reset your ECU, remove your positive terminal for at least 5 mins then hook back up see if it works.
Depicted Motion MR2
MR2QuiK is offline   Reply With Quote
Old 02-05-2004, 10:12 PM   #3 (permalink)
didnt work any other ideas why?
and has this happened to any one else?
Old 02-06-2004, 01:42 AM   #4 (permalink)
View mr2toy's Photo Gallery
Wink
check your supercharger belt tension, maybe it has gone loosed
mr2toy is offline   Reply With Quote
Old 02-06-2004, 08:02 AM   #5 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
gasman...ur sig pic is too big...please resize it accordingly......
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 02-06-2004, 09:15 AM   #6 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
although it is rather funny.
Brandon
arcasmachineracing is offline   Reply With Quote
Old 02-23-2004, 05:46 PM   #7 (permalink)
bcrdukes's Avatar
View bcrdukes's Photo Gallery
What kind of fuel are you using?
Also, did you check your battery and alternator?
1988 Toyota MR2 Supercharged - BCMR2 Owners Club
bcrdukes is offline   Reply With Quote
Old 02-24-2004, 01:19 AM   #8 (permalink)
91 octane
Old 02-24-2004, 01:23 AM   #9 (permalink)
bcrdukes's Avatar
Do the idiot lights go on? (Check engine, radiator, brake etc)
Are there any other symptoms?
Also, check to see if you have any vacuum leaks.
Old 02-24-2004, 03:56 AM   #10 (permalink)
all lights go on and all just doesnt boost when you step on it.
and how do you cheeck for vacuum leaks?
Old 02-24-2004, 12:25 PM   #11 (permalink)
bcrdukes's Avatar
You definately have an alternator/battery power related problem. First of all, how many volts is your battery meter showing? If you're getting around 12 - 14v, you're fine, but even though, check to see if your battery needs replacing.
Secondly, get your alternator checked out. It may be a problem where it doesn't hold the charge for your battery. Toyota designed the MR2 to flash all its lights when there's something battery/alternator related.
Go get that checked out first. I don't think its vacuum related at the moment from what you tell me.
