Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2009, 07:19 AM   #1 (permalink)
logimier's Avatar
View logimier's Photo Gallery
2nd Generation Help
Ok So I Was Told That Something With My Ecu Was Wrong Where Can I Go To Check What Exactly Is Wrong? Ive Done The Diagnose Check Nothing Reads Wrong... Now Just In Case Someone Asks Im Having Problems Reving Higher Than 500 Rpms I Was Told It Wasnt A Rev Limiter I Changed Spark Plugs,distributer,ect... Plz Help Me That Whole 5000 Rpm Supudder Is Getting Really Annoying
logimier is offline   Reply With Quote
Old 06-27-2009, 03:50 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I guess that was a Type-O and not 500rpm's but 5000.
Go thru all the systems.
Check your fuel filter.Make sure it isn't clogged and the engine is starving for fuel.Check fuel pump also.
Check your air filter. Make sure it isn't clogged and your engine is starving for air.Check AFM flap isn't stuck or restricted.(DO NOT REMOVE SCREWS!)
Check all vacuum line/hoses for cracks and leaks.
Check all IC heses for leaks.
Check fuel injectors. make sure they're not clogged.
Check all ignition components.-Spark plugs, Wires, Cap, Rotor.
The ECU make have detected a problem and put you in safe mode. It will keep your boost and rpms down.
The Jedi Speeder at CarDomain
Old 06-27-2009, 11:37 PM   #3 (permalink)
logimier's Avatar
Ohh really? hmm thanks man ill give all of that a try.....
Old 06-28-2009, 03:38 AM   #4 (permalink)
logimier's Avatar
Originally Posted by asjoseph View Post
... mind your firing order.
best,
- S a m u e l
im sorry what is it that youre trying to ask? i dont understand.......
Old 06-28-2009, 07:14 AM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
^ When you check your spark plugs and wires, etc., make sure they are hooked up right.
