coolant filling procedure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2009, 12:03 AM   #1 (permalink)
View mr2 cool's Photo Gallery
OK soooo i got it running but its runnin a bit hot so does any body know the coolant filling procedure? oh and special thanks to MR2 Jedi alllllot
mr2 cool is offline   Reply With Quote
Old 07-07-2009, 07:12 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
You're welcome!
Open the heater core bleeder valve located in the frunk(big white plastic screw) and fill at filler in engine compartment. You will also need to bleed air from the radiator by opening bleed **** on the top driver side of radiator. (you will have to lift the plastic guard next to driver side headlight assembly). Repeat until all air is evacuated and system is full of coolant/water.
Until all air is bled from system, you WILL experience overheating problems. Good luck
The Jedi Speeder at CarDomain
Old 07-07-2009, 07:36 AM   #3 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
Exactly. This is the most inefficient cooling system know to man. So it will take some time to bleed it right
TheEngineer is offline   Reply With Quote
Old 07-07-2009, 08:07 PM   #4 (permalink)
Audi Technician
View tHa kNiGHt FaLL's Photo Gallery
Yea I use a snap on coolant bleeder...... for the engine and then do the heater core and radiator. Sometimes you have to do it multiple times. drive it. do it again... gotta make sure you get it all out
tHa kNiGHt FaLL is offline   Reply With Quote
