shaved head=modded timing belt???
i had my 3sgte head shaved for my rebuild, but now the timing marks don't line up (the cams line up, but the timing pulley sits to the right of TDC by about 2 dgrees. and the stock timing belt that i'm using is getting chewed up during rotation. also, i pulled the plugs and #4 is black and the other 3 have a normal operating look. did comp test and its 150 all the way across. soooo... i was told that if i shaved the head and used the stock size head gasket, this might be the cause. any opinion's???
