Water Temp Gauge Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2009, 08:09 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I'm going to be installing an aftermarket water temperature gauge.
My question is : where is the best place for the sensor?
#1.) Hose coming out of the radiator
#2.) Hose going into the block
#3.) Hose coming out of the block(to me, this would reveal the most info as to the heat conditions in the block.)
Thanks guys, I value your advice.
The Jedi Speeder at CarDomain
Old 07-20-2009, 10:12 AM   #2 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
i beleive most people connect into an empty port on the water neck.
TheEngineer is offline   Reply With Quote
Old 07-22-2009, 12:15 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Good idea, but the one I was looking at uses an in-line hose sensor.
I will look into the type you're talking about.
Old 07-25-2009, 11:57 AM   #4 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Funny i see this thread as i installed one just last week onto my Camry. If the aftermarket sender has a 1/8 thread, you can pull the old sender out and put it in it's place; cheapest and easiest. Mine came with an M10, so i had to use an inline adaptor. I put it in the top radiator hose as it's only a bit past the engine outlet and hasn't been cooled by the radiator. Now you got to find out what temp is overheating.
Also, make sure your gauge's illumination turns off when the 'acc' is off. My cheapie gauge doesn't turn off and i didn't know until i put everything back together. I currently disconnect my battery terminal when i park it for a while, but i'm going to have to solder in a switch...eventally. Opening the hood everyday becomes such a PITA.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 07-25-2009, 12:10 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Well, I don't really want the stock gauge to be dead, so I wanna leave it hooked up. That way too, I can gauge what a nominal operating temperature is. The spot TheEngineer suggested is where you're talking about. So I think I will either use that one, or an in line sensor at the hose there-which is where you're suggesting.
I use fuse taps for power. Tapping at the "keyed " side of the fuse, thus it turns off when the car is off .Radio Shack sell these blade fuse taps.
Thanks Guys
Old 07-26-2009, 09:44 AM   #6 (permalink)
セクシーの定義
Thanks Guys
Just make sure the top radiator hose is the outlet from the engine; before it gets cooled by the radiator. I paid $30Au for the adaptor which i think is a rip as it was only a bit of metal. Cost the same as the gauge (got it off ebay).
And dang, i should've investigated fuse taps before i did mine lol. I spliced into the constant 12v for the headunit. There should be plenty for my Camry as i don't have power windows or mirrors lol xD
Camry history:
