3sgte 5sgte - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2004, 11:48 AM   #1 (permalink)
View W5sgte2.2's Photo Gallery
3sgte 5sgte
ok im trying to do some research on the 5sgte and am wondering if i should build it off the 5sfe block or the 3sgte blockim wanting to fully build the engine so i will be buying pistons cams vavles rods and ect but the engine is planned to go in to a mk1 so im wondering if the 5sfe block is much bigger than the 3sgte because space is an isue in this swap. So should i put the 5sfe cank in the 3sgte and build from their or just build up the 5s block with 3sgte head
Also i heard that a 3sgte angine will bolt to a 4age tranny
and im pretty sure it does because a 5sfe is in camry's and 20v 4age's go in those right
any info on 5sgte engines would be gtratley appriciated
W5sgte2.2 is offline   Reply With Quote
Old 02-12-2004, 12:28 PM   #2 (permalink)
ideas anyone
Old 02-12-2004, 03:51 PM   #3 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Not positive but...
I'm not positive but I belive the concept of the 5SGTE is to have a 5SFE bottom end and a 3SGTE top end. If you used the bottom end of a 3SGTE and the top end of a 5SFE you would have..... i don't know, a 3SFE? (i just made that up, dont quote me). My point being... GTE stands for G = Twin Cam, T = Turbo, E = Injected, and if you had the top end of a 5S-FE, you would be missing that small piece.... the turbo.
Old 02-12-2004, 05:01 PM   #4 (permalink)
well my idea is a 3sgte with just the 5sfe crank and then i would bye different rods and pistons
Old 02-13-2004, 09:40 AM   #5 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
technically its called a stroked 3s-gte because your still using the 3rd version on the S family series of blocks.
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 02-18-2004, 03:45 PM   #6 (permalink)
View seanmr2's Photo Gallery
both ways are done. 5sgte is out there as well. Full 5S block with GTE head, and a stroker kit for 3sgte. 5S crank and custom rods and pistons to make a 2.2L 3sgte.
85 tercel, sold
87 MR2, RIP
89 Corolla GTS, sold
91NA MR2, sold
93T MR2 for sale:
http://www.bcmr2.com/forums/phpBB2/viewtopic.php?t=2776
seanmr2 is offline   Reply With Quote
