stalling issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2009, 04:57 PM   #1 (permalink)
brandon_mr2's Avatar
View brandon_mr2's Photo Gallery
Gen1 stalling issue
89 na. I have always had the warm start issue, where it does'nt want to restart after it has ran for a bit. but now it has started dying when it it idles. from a cold start it runs perfect. but if u shut it off and restart it, it runs like crap, the engine stumbles, and it dies. it runs perfectly in cold weather. no issues during the winter months. any ideas?
brandon_mr2 is offline   Reply With Quote
Old 08-10-2009, 08:54 PM   #2 (permalink)
Gen1
i removed the egr a couple days ago, i did not seal the hole in the intake as good as i thought. so i had a vacuum leak. should have used a better gasket material. live and learn
Old 08-11-2009, 02:34 PM   #3 (permalink)
Gameroom cash: $134355
when I do this, I generally use stock metal (relatively thin) and then after it's bolted on, use a hammer and tap around the edges to get the metal of the plate to conform to the manifold..
sometimes, if it's salvagable, I will just use a stock egr gasket too.
