Originally Posted by onewingedangel326
I'm interested in turboing it and everything on it is stock. I found some kits for $3,000-4,000. They are only offering 6-8lbs of boost which will offer 75-100hp gain.
For that amount of money, you could get more boost than that.HP is not cheap though. You don't simply just slap on a turbo and take off. At that boost level, I doubt you will gain 100hp
I wanted something more around 12-14lbs. Is the 6-8lbs good enough because the car is so light? Or do you think I will be unhappy with it?
If you got 200 HP in your Spyder, as light as it is, it will be a kick to drive.Whether or not you will be happy with it-only you would know.
Where can I find other kits for my car?
What all do I need with a turbo if I don't buy a kit?
If I don't buy a kit where could I get all the pieces I need
There are lots of kits out there. Check out MonkeyWrenchRacing and SpyderChat.
When exhausts say catback, what exactly does that mean?
Exhaust that runs from the catalytic converter back to exhaust exit.
Does that mean I could remove my catalytic converter?
No, Thats against the law . You can only remove it for off road use.(track)
Will I need a turbo exhaust and whats the difference from a normal exhaust?
It would be best if you got a higher flowing exhaust for the turbocharging.
I read that my car is chain driven timing? If so that means I could put gear to gear timing in?
Yes, it has a chain. and no.What are you talking about?
Before starting a project like this, all your cars systems need to be in good running condition to handle all the stress' you will be putting on the engine-including brakes.
Set a goal you want to achieve with your Spyder and then do what you need to do to get it there.
You will need:
Turbocharger suited for your HP goals
Exhaust Manifold
Downpipe
An external wastegate if the turbo is not internally gated
Oil Lines for it and possibly water lines for bearing cooling
Intercooler , fan , piping ,couplers and clamps
By Pass valve of some type
A boost gauge(a must)
Boost controller of some type(whether manual or electronic)
Higher capacity fuel pump
Matching Fuel Pressure Regulator
And some type of engine management
(eg.-Megasquirt, Hydra, Greddy E manage)
You may also exceed your clutches holding capacity and may have to upgrade that as well.
I'm sure I've probably missed something. But thats the bulk of it.
Do you plan on doing your own work?
