exhaust leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2004, 10:48 AM   #1 (permalink)
View 91RED3S's Photo Gallery
exhaust leak
i have recently put a fel-pro exhaust manifold, along with new manifold studs, and have had no pwoblem with any type of exhaust leak whatsoever in that area, however, whil i had everything off i decided to change the turbo to manifold and turbo to downpipe gaskets, as well as the studs in those areas, since i changed those i have had to replace the studs for the manifold to turbo flange twice, the second time i installed bolts, they seemed to work for a little while, but have again started to leak, i was wondering if anyone knows any easier/better ways to tighten these bolts or a better way to fasten them altogether? all of this has happened over the last month
also, is the stock heat exchanger style gasket for manifold to head better then the fel pro's conventional style?
91RED3S is offline   Reply With Quote
