what a 3sgte fuel pressure should be at
I am new to the site and figured I would ask if anyone can help me out. I have been having issues with my 2nd gen 3sgte in my celica. It had a power loss in high rpms and any rpm about 80mph. I thought it was heat soak so I got a front mount intercooler.Still doing it.Changed all ignition parts, still doing it. Got all my intercooling pipes welded to get rid of any boost leak, still doing it.I am getting a lean code. All is on stock factory boost settings. I decide to change my fuel filter and fuel sock on the walbro fuel pump. Fuel filter is dirty put the new one on.Still doing it. I check my fuel pump and sock and the sock is clogged with crud and I figured the pump is not pumping enough fuel cause its clogged. I notice my tank is filthy and has crap all in it like a brown sludge. Should have dropped the tank and cleaned it but did not and just changed the sock. Well problem solved for about 2 weeks and it happens again mor an more as time goes by. Now its really bad and I dont drive the car.
Does anyone think by not getting the right fuel because its clogged and the same amount of boost it will make me get a lean code?
And what should stock fuel presure be. I am installing a fuel presure gauge tommorow and Want to see what it says. I will have to drop the tank I guess. Also thought it was the ebay dp hitting my wastgate still not sure about that.
