No problem.
If you feel that your ride is a tad bit too hard on turns/corners, do check up on the bushings on the car. My 88 Supercharged MR2 has a problem with steering especially on corners when I'm going a bit fast.
My car has been lowered and running on 16" Toyo Proxies. The suspension is really tight. Apparantly, my car hugs the road so I get a lot of bump steer but it seems as if its my bushings and control arm which needed attention.
If you do need bushings, I recommend the High'n'Tight Motor Sports polyurethane bushings. The bushings have been specifically designed by an MR2 enthusiast (Sarge) so you can trust his products 110%. Check em out.
http://www.highandtight.com
