p/s - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2009, 10:34 PM   #1 (permalink)
Henry0313's Avatar
View Henry0313's Photo Gallery
p/s
hi today my car was working perfect i took a 1 hour lunch went back to my car after my lunch drove it back to work but atg the time my p/s light camne on and my steering got stiff i have fluid in the resevoir does anyone know what could be the problem and how can i check if the power steering pump went bad
Henry0313 is offline   Reply With Quote
Old 09-27-2009, 11:51 PM   #2 (permalink)
Gameroom cash: $200266
View jkg065's Photo Gallery
Loose or broken p/s belt???
'04 Nissan Altima 3.5SE
'08 Corolla CE (wife's)
jkg065 is offline   Reply With Quote
Old 09-28-2009, 12:37 AM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
MR2's don't have power steering belts.
The Jedi Speeder at CarDomain
Old 09-28-2009, 12:50 AM   #4 (permalink)
Ooops, failed to see the car model!!!
Old 09-28-2009, 01:06 AM   #5 (permalink)
Mr2 struggles
View metallica786's Photo Gallery
I have that same problem as well. I just drove my car fine and then, the next day the p/s light came on and became stiff. Why is that?
metallica786 is offline   Reply With Quote
Old 09-28-2009, 08:47 AM   #6 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
The contact on the relay probably became stuck. Shut the car off and then cycle the key from Off to Accessory and back several times (20+ just to be on the safe side). Make sure you're not trying to start the car, but turn the key to the point just before it would start. This will often free up the relay and make the PS start working again.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 09-30-2009, 06:05 PM   #7 (permalink)
Henry0313's Avatar
thanks yea i turn the ignition on and off after 5 times i turn it on thanks that help, its that normal
Old 10-01-2009, 11:32 PM   #8 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Not "normal" per se, but it happens frequently enough. Glad it worked for you!
Old 10-01-2009, 11:35 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Mine has done that a couple of times over the years. Eventually it just comes back on.. I'll know what to do next time..
Good info Ben...
Old 10-05-2009, 06:52 PM   #10 (permalink)
Henry0313's Avatar
2 time for me
