Yes, aftermarket BOVs are good for noise (which is cool
), but they rob some level of performance ... and it doesn't matter what turbo you have.
The OEM valve is the best valve you can possible have under all conditions except ONE. That condition is if you are flowing enough VOLUMN (huge boost, huge turbo) that requires a larger valve. That being said, the best valve in that situation would be the OEM design but larger.
99.9% of people will never see that level of boost.
Originally posted by ishcoleobo
That is of course only if you are running a stock turbo setup I would suppose? Otherwise there would be no reason for a BOV.
Doesn't matter what set up you have.
There is a reason for a venting valve, whether it be a BOV or BPV, regardless of what turbo set up you have. The reason is to stop pressureized air from trying to spin the turbo in the wrong direction.
