Tire Size? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2004, 06:55 AM   #1 (permalink)
View B3A5T's Photo Gallery
Tire Size?
I am about to get rims and tires for the 91 Na mr2 i just bought and i obviously want the back tires to be wider than my front. So, I was wondering how wide of tires (on 18" rims) can i put in the rear without alot of modication (a.k.a cost alot of money)?
*edit*
Wait can I even fit 18 inch rims on my mr2?
B3A5T is offline   Reply With Quote
Old 02-25-2004, 08:01 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
u can fit 18s no problems....any wider then 235s in size...n u will have rubbing issues depending on what suspension setup ur car has....go with a 9" wide rim if ur going with 18s....but they will slow u down....go with 17s would prolly be better unless u really want the bling...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 02-25-2004, 09:43 AM   #3 (permalink)
Mmm, I love turbos!
View RePete's Photo Gallery
I had 18" wheels in 255/35 in the rear of my MKII for about half a year and it fit fine. It was a rough ride though and there isn't much sidewall so a bent rim is always around the corner, they're also heavier which can affect handling. 17s are probably the best compromise of performance and looks on the MKII. I find 17s look larger than they are because the car and beltline is low, especially in the front where the fender leaves a great looking bump in the lines of the car which accentuates the wheel well.
IMO, 18s are pushing the bling-bling effect overboard and I did not notice ANY difference when I went to 245/40-17s in the rear (except a nicer ride).
RePete is offline   Reply With Quote
Old 02-25-2004, 10:02 AM   #4 (permalink)
^^u didnt have to roll ur fenders to fit 255s??....n it didnt rub??..is ur car lowered??.....
91 mr2..07 335i..
Old 02-25-2004, 11:42 AM   #5 (permalink)
Mmm, I love turbos!
Stock '91 suspension, no rubbing, no rolling of fenders. Offset was ET45 which did the trick.
