need help overheating true or fals - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2009, 05:28 PM   #1 (permalink)
Henry0313's Avatar
View Henry0313's Photo Gallery
hey hows it going i have a 91 mr2 n/a
I took it to a mechanic it has been 2 weeks and he story is tht my fans are not turning at the temp there suppose to turn on.
He told me they turn on late after the temp original temp its suppose to turn on.
He told me he has to reprogram the computer dont know which one, but that he has to reprogram it for the computer could tell when the fans should turn on and stay on for the fans wont start at the temp when its over heating is this true or false
Henry0313 is offline   Reply With Quote
Old 11-19-2009, 05:29 PM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304505
View MrSo0h0o's Photo Gallery
i would check the thermostat to see if it is stuck open or closed.
MrSo0h0o is offline   Reply With Quote
Old 11-19-2009, 05:36 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Didn't you change your thermostat a little while back?
I think thats BS.. Theres a sensor that tells the the fans when to kick on. I think I would test that before I started paying someone to reprogram my ECU.
Though I had a '92 N/A , besides regular maintainance, I never did anything else to it. So I'm not all that familiar with it(plus I got rid of it in '95).
The Jedi Speeder at CarDomain
Old 11-19-2009, 05:43 PM   #4 (permalink)
Henry0313's Avatar
yea i did and the thermostat its ok
Old 11-24-2009, 12:15 PM   #5 (permalink)
View TAZZX2's Photo Gallery
Please correct me if I'm wrong but arn't the rad fans ran off a temp sensor switch at the rad (you unplug it and the fans run constant) So if they are turning on late wouldn't it be because the temp sensor is reading wrong and not problem in the comp... Maybee replacing that sensor would fix your prob.
If your reading hot and the fans arn't coming on double check that you don't have an air bubble in the cooling system. If air hits the temp sensor for the gauge it will shoot up but the coolant won't be that hot. Try rebleeding the system, grab a ir/laser thermometer and watch the temp with that untill the thermostat opens. With such a long cooling system it can take a while for the therm side to warm up to the point it opens. gl
TAZZX2 is offline   Reply With Quote
Old 11-25-2009, 03:22 AM   #6 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
Just to start off, to reflash your ecu because of your radiator fans don't turn on is just ridiculous. I suggest never bringing your car to that establishment again.......
Now, there are a number of things that can cause your fans not to turn on....... And to completely diagnose the problem, we'd need more information from you.
First thing I'd do is unplug the temp. sensor at the radiator. When you unplug the sensor, the fans should run at high speed all the time (with the ignition on, of course). If the fans turn on, that's a pretty good indication your fan control circuit is functioning properly........
Try this and we'll go from there........
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
