3sgte leaking coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2009, 09:26 PM   #1 (permalink)
white hands.. dark clouds
mrtuan's Avatar
View mrtuan's Photo Gallery
Recently i've noticed hissing noise coming from the engine when it turns off so i checked underneath to find coolant leaking. Upon closer inspection i noticed it came from a metal water piping to the left of the block (next to the wastegate) and i could see bubbling coming from the pipe. I've done a bit of research and think its a heater pipe. Any suggestions or has anyone been through this before?
miSta tWo ^.~
mrtuan is offline   Reply With Quote
Old 12-02-2009, 12:59 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
There are 2 other coolant lines coming off that water inlet. 1 goes to the Turbo and the other to the throttlebody. I would make sure which hose it is.
If it is the heater hose, you can bet the others aren't far behind if you've never changed them. The heater hose is an easy fix. the other 2 are a PITA, but not too bad.
Heres a pic to help you identify the different lines.
The Jedi Speeder at CarDomain
Old 12-06-2009, 07:10 PM   #3 (permalink)
mrtuan's Avatar
hi mr2jedi, i cant seem to see the pipe in the photos you provided so i was gona take it apart to identify it but thought it'd be easier to take a pic of it. here it is.
http://s854.photobucket.com/albums/a...rent=bust2.jpg
http://s854.photobucket.com/albums/a...rrent=bust.jpg
What pipe is this one?
miSta tWo ^.~
Old 12-06-2009, 08:09 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Thats a by pass line for the turbo. There are 2, one in and one out.
Old 12-06-2009, 10:48 PM   #5 (permalink)
mrtuan's Avatar
how do i go abouts changing that?
miSta tWo ^.~
Old 12-06-2009, 11:36 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
It's just a short piece of hose. It's hard to get to, but not impossible. It's easier if you remove whatever is in the way.
