Clutch is Stuck..whats next - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2009, 07:00 PM   #1 (permalink)
View Myron's Photo Gallery
Hey guys, ive been on here but with my other toys..
I bought a 86 MR2 last week, and while driving, my clutch could not engage.
So now i can go through all the gears with my car on but my clutch pedal is STUCK. can not pe pushed in (engaged)
what do you guys think, Tranny or Clutch???
Thnx for he input
Myron is offline   Reply With Quote
Old 12-25-2009, 09:41 PM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
clutch master/slave cylinders may be bad. that would be the first thing i would check. check fluid.
1/2 a tank of V-Power gas+ 1/2 tankful of fuel with Techroline= V-Tec gas??? Speed and grip walk a very thin line of balance. If a car feels like it's on rails, then you're probably not going fast enough.
ToyotaTechGeek is offline   Reply With Quote
Old 12-25-2009, 10:09 PM   #3 (permalink)
Fluids are good, ill check the cylinders
thnx
Old 12-26-2009, 09:00 AM   #4 (permalink)
also inspect clutch slave hydraulic line. check for bulging, scrapes/cuts/abrasions/dry rot. you may also try bleeding/changing the hydraulic fluid.
