More Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2010, 06:19 AM   #1 (permalink)
View drunkshopper's Photo Gallery
More Problems
Okay this whole cooling/heating system is driving me nutz! Anyways I just got a coolant flush, and found out that my water pump is leaking. so i know i have to replace that, but another problem is that all of a sudden, I dont get any heat anymore. I blows really cold air. Being that it is winter, so I would love to have heat. Any help would be great. thanks for the help guys.
I have a 93 Mr2 T.
drunkshopper is offline   Reply With Quote
Old 02-04-2010, 06:46 AM   #2 (permalink)
Gameroom cash: $253010
iTrader Score: 6 reviews
View BDSL's Photo Gallery
Your coolant plumbing might have some air in it. Make sure you fill it as per BGB or
http://www.mrtwo.net/mr2modproject/mr2modproject.htm
BDSL is offline   Reply With Quote
Old 02-04-2010, 01:39 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
View MR2Jedi's Photo Gallery
No heat after flush = air in heater core.
You need to open the frunk and on the front wall there is some plumbing with a big white plastic screw to bleed out the air with.
You also need to bleed air out of your radiator via the air **** on the top, driversde of the radiator.
The Jedi Speeder at CarDomain
Old 02-05-2010, 08:27 AM   #4 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
thats why i never bring this car anywhere for work. Because no shop knows the correct way to do things. The cooling system is one of the biggest pains on this car and bleeding it is a process. LIke they said, follow the BGB and youll be good to go
TheEngineer is offline   Reply With Quote
Old 02-07-2010, 04:24 AM   #5 (permalink)
View GeoffBooth's Photo Gallery
Also, it's always a good move to replace the Therostat.
GeoffBooth is offline   Reply With Quote
Old 02-07-2010, 01:36 PM   #6 (permalink)
Okay so I bleed the car after our snow, wow a ton of air in the system. Anyways it doesnt seem to be overheating anymore....Fingers crossed, but there is still no heat coming from the vents. any idea guys? Thanks for all the help.
Old 02-09-2010, 06:57 AM   #7 (permalink)
K this is getting crazy. So I aired, or tired to air out the system again. I have come up with to conclusions, either I am doing it wrong, or I have more air in my system than fluid in the car. Anyways I let it run for close to an hour. I never saw a steady stream of fluid. So any idea guys?
Old 02-09-2010, 11:33 AM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Where exactly are you bleeding from? Your post is very vague.
Old 02-09-2010, 11:46 AM   #9 (permalink)
I have bled , or tried to bleed air for both the radiator and heater coil vents.
Old 02-09-2010, 12:01 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Well, I don't know what to tell you. It's an easy process. With egine running, bleed both those areas, then add coolant/distilled water several times. Bleed, add, bleed, add.
Old 02-09-2010, 12:06 PM   #11 (permalink)
I know it should be, but im not getting any coolant coming out. its just really hot air, an maybe a spit here or there but for the most part it will give a little and than nothing but air.
Old 02-09-2010, 12:08 PM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Do you have the heat on when doing this?
Old 02-09-2010, 12:09 PM   #13 (permalink)
Yea, I turn it to the setting with 2 dots. of it would make it the 3rd setting.
Old 02-09-2010, 01:19 PM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
With the temperature slide all the way to high heat?
Old 02-09-2010, 01:21 PM   #15 (permalink)
I think it was one away from high heat... So our you telling me to put it on high heat?
