Is my engine locked????????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2004, 07:38 PM   #1 (permalink)
1993 MR2 Turbo
View josephah2000's Photo Gallery
OK, first off my engine will not start. I hear a clicking sound. (battery is good, starter is good, ignition switch???? who knows)
Now it seems I have bigger problems. Today, I tried to start it with the clutch by pulling it with my truck. When I pop the clutch the rear tires lock and of course the engine does not start. There were no signs that I had a problem with my engine prior it not starting. Again I initially thought it was the starter.
What's going on? Did I lock my engine?
93T Lightly Modded @ 15 p.s.i.
josephah2000 is offline   Reply With Quote
Old 03-14-2004, 08:24 PM   #2 (permalink)
View pdxvento's Photo Gallery
you mean is your engine seized? see if you can turn the engine over by hand. if you can, which im assuming you probably will be able to, then it isnt the engine itself.
WANT TO BUY: a 91-95 MR2. it can have damage or a blown engine...pretty much looking for a rolling shell on the westcoast for under $1000. Email me @
hirkoj@onid.orst.edu
pdxvento is offline   Reply With Quote
Old 03-14-2004, 09:17 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
Does the tires slide in 4th gear? If so then yes it is locked.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 03-14-2004, 09:59 PM   #4 (permalink)
1993 MR2 Turbo
I only went up to third gear. What is the difference?
Old 03-14-2004, 10:50 PM   #5 (permalink)
bcrdukes's Avatar
View bcrdukes's Photo Gallery
clicking sound = get your starter checked out.
1988 Toyota MR2 Supercharged - BCMR2 Owners Club
bcrdukes is offline   Reply With Quote
Old 03-15-2004, 11:40 PM   #6 (permalink)
1993 MR2 Turbo
Ok, I just found out there was water covering my spark plugs. Apparently water had seeped down there and that is why my car wouldn't start.
Can this cause the engine to lock?
Old 03-16-2004, 06:31 AM   #7 (permalink)
N/A bites
Tercel GTS's Avatar
4th is direct drive, easiest to roll. Water in the cylinders can do much worse than just lock it. Like bent rods, broken pistons, cracked head, or even a busted block. I'm sure at minimum you need a head gasket.
雄のハヤブサ
Old 03-18-2004, 11:55 PM   #8 (permalink)
1993 MR2 Turbo
Do you believe in God? All of a sudden it started turning. Now all I have to do is get it started.
Old 03-23-2004, 11:59 AM   #9 (permalink)
View MitchB's Photo Gallery
And get the leaking head gasket fixed.
MitchB is offline   Reply With Quote
Old 03-23-2004, 07:39 PM   #10 (permalink)
N/A bites
Tercel GTS's Avatar
And replace the rod that bent allowing it to turn.
雄のハヤブサ
Old 03-24-2004, 06:15 PM   #11 (permalink)
1993 MR2 Turbo
I can't explain it. I know that does not make sense. The only problem is it seems to be lacking power in second gear, but I think it is fuel or air intake related and not the engine. When I changed the engine oil there was water mixed in. As far as I know, there are no leaks.
Old 06-04-2004, 04:02 PM   #12 (permalink)
View redragon005's Photo Gallery
If there was water in your oil(which is probably actually coolant), you have a blown head gasket.
I want my engine to rev real high, and I want my car to turn fast - that is all.
redragon005 is offline   Reply With Quote
Old 06-10-2004, 08:54 AM   #13 (permalink)
View boricua52385's Photo Gallery
sounds like a head gasket, when you put the new one it, try and get your engine flushed out, and keep changing your oil often until all that coolant is gone. Anything other than oil trying to lubricate your engine can do a lot of damage and cost big $$
boricua52385 is offline   Reply With Quote
Old 03-08-2005, 10:35 PM   #14 (permalink)
1993 MR2 Turbo
Update:
It is running awesome. I have taken it up to 130+ miles per hour and it can go 0-60 in about 5 sec. No complaints!!!
Old 03-09-2005, 06:46 AM   #15 (permalink)
Great! But it's not much of an update if you don't tell us HOW you fixed it!
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
