92T Exhaust Manifold Leak
I can always count on you guys for good advise. I replaced my turbo last year with an ATS CT27. I broke the manifold stud in the head closest to the driver's side (same one Lovehorsepower broke). The stud was replaced and the work continued. The stock manifold was milled flat, both on the head and turbo side. I had some slight fitment issues at the cat bracket due to the amount of material removed, but all went well. New seals/gaskets all around. All torqued to spec.
A year later the repaired stud loosened up and caused a leak. I tigtened it, but it still leaks very slightly, although not as bad. It is the classic exhaust manifold leak---only makes noise for a minute or two when the engine is cold.
Any advice (BGB no help)?
Can I change the manifold, without ripping out the turbo, elbow, cat, downpipe, etc? I suspect the manifold change will be like a turbo swap all over again. Not fun anymore.
Oh yeah a new manifold is almost $300 from Toyota !!
thanks..............
