5psi is about as high as you want to push on a factory ECU/tune. at 7psi and above, the cast pistons really do take a lot of punishment, and will fail over time.
do NOT swap over to turbo cams - the NA cams have higher lift and longer duration than the Turbo cams.
the 2nd gen 3SGE you have, also does not have TVIS (like the 1st gen). instead, you have ACIS (same as 1987-1992 Supra). no need to change anything there, as it manages itself quite nicely.
even though the 3SGE rods are cast, they are still quite strong.
the head gasket is the same between the 3sge and 3sgte - so, no need to worry there either.
for the time being, keep the boost low (5psi). when you upgrade the pistons and rods (with forged pieces), you can then increase the boost.
i would recommend looking into a separate oil cooler just for the turbo, and if possible, look into an air-to-water intercooler setup. this setup is on the celica gt4.
the air-to-air intercooler setup requires a lot of piping, and is not very efficient. if you get above 350hp, then air-to-water will reach its limit and you will want to use air-to-air.
as stated above, with a twin turbo setup, it would be difficult to build up enough exhaust flow to make it worthwhile. you could do something very unique and look into Twin Charging it (ie. Supercharger and Turbocharger). with a Twin Charged setup, you get all of the boost from the supercharger for low to mid rpms, and the turbo takes over for mid to high rpms.
if you pursue the twin charged setup, a few vehicles have already done it.
http://www.club4ag.com/faq_and_tech_...ifications.htm
it was mainly done with the 4ag platform, but a few Rally cars have also used this sort of setup. it is VERY complicated, but fast beyond belief.
http://sccaforums.com/forums/storage/52/389917/s47.jpg
Lancia... perhaps the Delta S4?
http://media.photobucket.com/image/t...winCharged.jpg
Pontiac GTP
