88 MR2, GZE idle issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2010, 11:21 PM   #1 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
i just cant seem to get it to idle properly, so ive already checked the coolant level and its fine.... im not quite sure what could be the issue.... when i unplug the idle control valve it doesnt make any difference.. it still does the idle hunter bit, fluctuating between 1000-1500 rpm, is there anything i can check, ive already waited twice for it to get to operating temp to see if it levels out but no luck
4agetercel is offline   Reply With Quote
Old 04-21-2010, 06:53 AM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
was coolant serviced recently? coolant level and coolant properly bled are two different things. one must bleed the coolant as per specifications in BGB. also, is your TPS properly adjusted?
1/2 a tank of V-Power gas+ 1/2 tankful of fuel with Techroline= V-Tec gas??? Speed and grip walk a very thin line of balance. If a car feels like it's on rails, then you're probably not going fast enough.
ToyotaTechGeek is offline   Reply With Quote
Old 04-21-2010, 09:16 AM   #3 (permalink)
Wonderbread
4agetercel's Avatar
i have no idea on either of those things, ive only owned the car for 3 days now, it did sit for a couple years before i got it,
the TPS still has the yellow factory stuff on the screws so i dont think it was tampered with,, also to "propely" bleed the coolant system, does it have something to do with the one screw on the thermostat hosing?
Old 04-27-2010, 10:42 AM   #4 (permalink)
yes, there is a specific set of directions for bleeding coolant.
Old 04-27-2010, 05:33 PM   #5 (permalink)
Wonderbread
4agetercel's Avatar
Well i solved the idle hunting problem, now I'm left with it idleing at 1200 rpm at operating temp, the idle screw is all the way in, and I checked the tps and it's fine
Old 04-27-2010, 08:45 PM   #6 (permalink)
ok, remove the throttlebody and soak it! and scrub it! there are lots of nooks and crannies that get clogged-up with crud.
Old 04-27-2010, 08:54 PM   #7 (permalink)
Wonderbread
4agetercel's Avatar
Done and done, I took it off and clean the trottle body and the idle air control valve... That's how I got it to stop fluctuating
Old 04-28-2010, 06:53 AM   #8 (permalink)
it fixed your high idle as well, right?
Old 04-28-2010, 09:33 AM   #9 (permalink)
Wonderbread
4agetercel's Avatar
..... Nope not even close, still revving around 1300
Old 04-28-2010, 11:41 AM   #10 (permalink)
reset the ecu (hard power-down) by disconnecting the battery terminals. back idle set screw all the way out. hook-up battery leads and start vehicle. adjust the idle screw.
try that.
Old 04-29-2010, 06:20 PM   #11 (permalink)
Supercharzed Toyz Raczing
mr2tim's Avatar
View mr2tim's Photo Gallery
I'm wonderin' whether the PO tinkered with the idle stop screw. It's the adjuster with locknut on the lever where the throttle wire is. If the PO dicked around with it you'll have to rest the TPS per the BGB technique. It's a easy procedure. Do you know how to acces the BGB via Internet?
You stated that the TPS still has the OEM paint on the adjuster screws so odds are it hasn't been moved.
mr2tim is offline   Reply With Quote
Old 05-03-2010, 09:49 PM   #12 (permalink)
Wonderbread
4agetercel's Avatar
BGB? That's was a whole other language to me, well I've tried everything ttgeek has suggested and nothing, it's idleing at 1400-1500, 14 is the lowest it gets.... If I drive it, shut it off and re-start it it will idle at 1000, but it will go back up to 1400.... I have no idea wtf is wrong, all vac hoses are hooked up can't find a vacuum leak, tps is good,,, afm isn't sticking
Old 05-03-2010, 09:54 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
BGB= Big Green Book. THE Toyota Service Manual
The Jedi Speeder at CarDomain
Old 05-03-2010, 09:55 PM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Does the 1st gen use a cold start injector? with a timer switch?
Old 05-03-2010, 11:45 PM   #15 (permalink)
Wonderbread
4agetercel's Avatar
Don't know about a timer but yes it does have a cold start injector
