Turning on headlights causes stalling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2010, 11:33 PM   #1 (permalink)
View Ibis's Photo Gallery
I have an 85 MR2, when I turn on the headlights, rpm's drop and the car stalls without a bit of throttle. any Ideas?
Ibis is offline   Reply With Quote
Old 05-07-2010, 12:19 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Head lights are a big draw of power.
Bad battery or alternator. I would also check the headlight wirng for a bad ground, bare wire, etc.
The Jedi Speeder at CarDomain
Old 05-09-2010, 07:12 PM   #3 (permalink)
View crazygavman's Photo Gallery
take the car up to your local autoparts store advane, autozone, orillys ect. and tell them you need your charging system tested. im pretty sure its the alternator though. good luck!
crazygavman is offline   Reply With Quote
Old 05-12-2010, 12:29 AM   #4 (permalink)
If i keep the throttle on just alittle its fine, but without, rpm's drop to 400-500 and eventually stalls, if I'm driving and clutch in while slowing down, rpm's drop to nothing and the engine stalls.
Old 05-12-2010, 01:51 AM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Again, check your charging system.1st check the belt. make sure it's tight. Then the Battery, alternator , battery cables and connectors.
Old 05-20-2010, 01:33 PM   #6 (permalink)
Supercharzed Toyz Raczing
mr2tim's Avatar
View mr2tim's Photo Gallery
Mark1 NA cars have voltage regulators built into the rear of the alternator.
Your alternator may be just fine, but the regulator could be the problem.
If you take it to a rebuilders shop he could exchange the regulator without having to trash the alternator.
(cheaper)
Think recycle.
mr2tim is offline   Reply With Quote
