Originally Posted by TheEngineer
both of these guys are highly reputible on the mr2 forums!
I believe that the second link, MR2 warehouse, is known as the "traveling mr2 mechanic" and will install the motors for a very reasonable rate.
The motors are essentially the same, the one you want, known as the Gen3, has a re-designed head which flows more; they also have larger lift and duration cams, toyota dropped the hair dryer of a ct26 turbo and upgraded to the ct20b; they do not use an AFM, it was changed to run off the MAP sensor only, and the injectors were upgraded from 440cc to 540cc. I believe that the intake manifold also had a few changes, but once you upgrade the turbo it is still a bottle neck!
