3SGTE: Gen 1 vs Gen 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2010, 07:16 AM   #1 (permalink)
View slugg#3's Photo Gallery
Question 3SGTE: Gen 1 vs Gen 2
Just by looking, can you tell the difference between gen 1 and gen 2 block. I'm not talking about the complete engine, but just the short block alone.
I know that the gen 3 and gen 2 has different location of the oil filter.
Anyone?
slugg#3 is offline   Reply With Quote
Old 06-02-2010, 02:58 PM   #2 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
im not sure the outside of the gen 1 looks any different but i know the internals are. Why would you want a gen 1 anyway? do yourself a favor and just stick with a gen2
TheEngineer is offline   Reply With Quote
Old 06-02-2010, 11:44 PM   #3 (permalink)
not12listen's Avatar
View not12listen's Photo Gallery
well... a few details.
1st gen 3sgte ONLY (in the US) ever came in the AllTrac Celica. this had a small air-to-water heat exchanger resting over the head of the engine. later models of the AllTrac Celica had either larger air-to-water heat exchangers OR air-to-air intercoolers (depending on which country its from).
the Mr2 uses an air-to-air intercooler setup.
here are examples of each:
1st Gen 3sgte - USDM AllTrac Celica
2nd Gen 3sgte - JDM AllTrac Celica
2nd Gen 3sgte - USDM AllTrac Celica
2nd Gen 3sgte - USDM Mr2 Turbo
hope this helps.
not12listen is offline   Reply With Quote
Old 06-27-2011, 07:05 PM   #4 (permalink)
View takopako28's Photo Gallery
would any generation be able to fit into a 1988 toyota camry wagon le? im looking for swaps to put into my shagon wagon lol
takopako28 is offline   Reply With Quote
Old 06-27-2011, 07:11 PM   #5 (permalink)
if your Camry Wagon comes with the 3sfe, then the 3sg(t)e is a direct drop in. you will need to sort out the wiring and transmission issue of course.
i cannot comment if your Camry Wagon has the 3VZ (v6) option.
Old 05-25-2012, 03:00 AM   #6 (permalink)
its actually an 87 camry wagon le
Sent from my VM670 using AutoGuide.Com Free App
