Driver door doesn't close properly - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2010, 10:19 AM   #1 (permalink)
dirnt's Avatar
View dirnt's Photo Gallery
Hi again guys
Now that I have the mould problem fixed I'm looking at the reason behind it.
Ever since I got it I've noticed that my diver side door doesn't close properly. I for some reason never took any real notice of it until now.
What's happening is I close the door and it does a sort of jump just before it closes. Not the best explanation I know but when it closes it doesn't sit in the exact same position as the passenger side.
Has anyone else had/having this problem? Would you know if all i have to do is play with how the door sits. I read you can adjust vertical and horizontal.
dirnt is offline   Reply With Quote
Old 06-02-2010, 11:13 AM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
Your door is not aligned properly to the frame. This can be caused by someone who took the door off the car and didnt take the time to put it back on properly. Its rare that the door sags enough to cause what you are describing.
What to do:
1) Open your door fully, look from the outdide of the car towards the front of the door, between the door and the fender you will notice the large door hinges. You will need access to these.
2) The best way to access the hinges is unfortunately to remove the fender. Once you have the fender off you will have an easier time with the door alignment.
3) Open the door just enough so you can get a small floor jack under the end of the door. make sure the jack is under the door but not pushing up on it. just so the door is lightly resting on the jack. Use a cloth or block of wood so you dont damage the door.
4) Loosen all 4 bolts on the two hinges equally so they are loose enough so that the door can be adjusted.
5) Jack the door up by a tiny amount, then re-tighten the bolts. remove jack and test door for contact issues. If contact issues still exist then repeat above process.
Sometimes the door can be too high or low, so before you start make sure you look at the top body line of the door (where window frame is) and make sure to note how it is lined up with the top body line of the rest of the car (especially around the back end of the door.)
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
The Following User Says Thank You to ModifierMR For This Useful Post:
dirnt (06-05-2010)
Old 06-03-2010, 09:57 PM   #3 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1343766
iTrader Score: 7 reviews
Originally Posted by dirnt View Post
Hi again guys
Mine does that because the hinges are worn out, after all they are 21 years old! I have new hinges that I just painted & I'm putting on this Saturday.
ROTM November 2011 Winner!
SuperchargedMR2 is offline   Reply With Quote
The Following User Says Thank You to SuperchargedMR2 For This Useful Post:
dirnt (06-05-2010)
Old 06-05-2010, 03:54 AM   #4 (permalink)
dirnt's Avatar
Thanks heaps guys
It's been frakin raining here non-stop for the past 2 weeks, so when it stops i will give it a go, but sounds like this is deffinately the way to fix it.
