grinding when shifting...syncro? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2004, 02:28 PM   #1 (permalink)
View jdmsw20's Photo Gallery
Exclamation grinding when shifting...syncro?
I have heard of people having this problem before, but I was wondering that when i shift fast and it makes a grinding sound while entering the gear, is it my transmission syncro......how much would it be to fix and how important is it to fix? And yes I know for sure that I have the clutch all of the way in whne I shift...thanks
-Stephen
dont be scared of too much power, be worried about loosing without it!
jdmsw20 is offline   Reply With Quote
Old 04-01-2004, 02:31 PM   #2 (permalink)
View 91RED3S's Photo Gallery
it could just be worn out clutch lines or maybe you are in need of pedal adjustment or bleeding and new fluid in the system
complete JDM Gen 2 engine, Tubular stainless manifold and 3" downpipe, Turbo XS Type H RFL blow-off-valve, Konig Holes 17" rims, Faze Boost Gauge, soon: HKS Vein Pressure Converter & Fuel Cut Defender, KYB AGX Struts, RS*R RACE Springs
91RED3S is offline   Reply With Quote
Old 04-01-2004, 02:50 PM   #3 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
is it usually 2nd gear? If so, its common on pre-93 turbo trannies.
ratko.org
Ratko is offline   Reply With Quote
Old 04-01-2004, 03:22 PM   #4 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
when was the last time u changed tranny fluid??...try using redline products or GM syncromesh....that may help somewhat...if its ur synchros...time to rebuild tranny....93 lsd would go nice..
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 04-07-2004, 07:16 PM   #5 (permalink)
thanks.....I was planning on using that syncromesh nixt time I needed to change the fluid, I will see if that works!
