VSS/SPD Wire - 5V or 12V Pulses? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2010, 05:34 PM   #1 (permalink)
View gdirwin's Photo Gallery
I am using a MR2 MK3 (2003?) P/S pump in my electric car (I am converting a 2001 RAV4 to an all-electric).
The wiring diagram for the P/S pump shows 3 connectors - the middle connector has an input SPD (middle connector P7, pin 2, violet/white) from the combination meter.
I understand this signal is similar to VSS (ie 4 pulses per revolution) and is used by the P/S ECU to slow down the P/S pump at high speeds (ie de-sensitize the steering).
Is this signal a 5V pulse or a 12V pulse?
I found a VSS signal on my RAV4 (also Violet/white) - I scoped it and it has 4 pulses per revolution, but is 5V.
Can anyone tell me if the Violet/white wire on their EHPS pump (8 pin middle connector) shows 5V or 12V pulses?
All help appreciated!
Wiring diagram below:
gdirwin is offline   Reply With Quote
Old 07-12-2010, 03:34 PM   #2 (permalink)
Bump - anyone know if the SPD signal into the power steering ECU is 5V or 12V pulses on a MKIII MR2?
