head lift w/ ARP head studs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2010, 02:13 PM   #1 (permalink)
View jesse0880's Photo Gallery
My motor is knocking pretty bad and I believe it might be the ARP head studs at fault. I have read a few posts about this but I was wondering how common it is. I just rebuild my motor maybe 200 miles ago and I was told that I need to retorque the nuts.
I already pulled the oil pan off and checked the main bearings and rod bearings and none were spun.
jesse0880 is offline   Reply With Quote
Old 07-25-2010, 02:20 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I'm using ARP's and I retorqued them after 1K miles.
Sometimes the stud doesn't seat all the way into the block.Just make sure you do it in the correct sequence .
I did 50ft/lbs , then 60 ft/lbs.
A couple of them turned a 1/4 turn before hitting 60..
The Jedi Speeder at CarDomain
Old 07-25-2010, 05:09 PM   #3 (permalink)
Russell D's Avatar
View Russell D's Photo Gallery
Did you use the ARP thread lube when you torqued them?
-91 Mr2Turbo-363WHP/289WTQ
I'm not happy, More power coming...
Now 386hp/300tq and still not happy
-94 Toyota Pickup SR5-
Russell D is offline   Reply With Quote
Old 07-25-2010, 05:53 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
If you're asking me, yes.
Old 07-25-2010, 06:07 PM   #5 (permalink)
Russell D's Avatar
^^not so much you because you aren't haiving issues!
Old 07-25-2010, 06:13 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Ok, just checkin. I didn't want to ignore if you were.
Old 07-26-2010, 12:05 AM   #7 (permalink)
Sure did, but this is my first rebuild EVER...I'll be pulling off the valve cover the next chance I get.
Old 07-26-2010, 08:02 AM   #8 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
Ive used ARP studs on many cars and none have had issues. If its a fresh rebuild, have you been breaking it in properly? Have you kept it under 3,000 RPM?
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 07-27-2010, 08:13 AM   #9 (permalink)
I've kept the RPM's pretty low up untill the about the time the problem started.
Old 07-27-2010, 08:22 AM   #10 (permalink)
Midship Captain
ModifierMR's Avatar
So around the time the problem occured were you starting to open it up or what?
すべての日本への私のお悔やみ。
Old 07-29-2010, 10:16 PM   #11 (permalink)
Russell D's Avatar
How much did you torque the nuts?
What kind of torque wrench did you use?
Tags
head bolts
