Originally Posted by freddy121389
awesome the answer i was looking for and i assume you ment to type '01, do you think its safe to push around 15psi on stock internals or stick to more around 12psi, I've seen 12psi done so I know that's safe.
Oooops, yes, '01.(edited)
I had already started building mine until I found this '91 in pretty shape. So all the money started going to the '91.
It's all about tuning as far as boost goes. But I think if I was going to go above 12 psi, I would be using forged internals.
But again, it's all about proper A/F ratio, ignition timing and charge cooling.
