1992 Mr2 Turbo - Iceland - loads of images - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2010, 09:57 AM   #1 (permalink)
View Turbo-'s Photo Gallery
i bought the car back in 2005 when i was 15 lol, got it for cheap as it had driven on horse and looked bad, but me and dad fixed it, we are both body mechanics, work with dented cars every day
anyway
the car came to my like this after a crash with a horse:
i was a little exited when he came to my garage, so one shaky pic for u guys
Then me and Dad went into repairing
stage one : top into right position
stage two : fix the holes on the top (we pulled them up so its not just filler)
stage three was all the body
Then we went into the painting section
then the car was painted with primer ? or sum (dont know the english word)
then he came to my garage after painting
after that came the big puzzle
the windows came tinted from my friend, he owns a tint company
the rims
now last january the engine said goodbye with loss of 8 bars in compression on 2 cylinders so i went into tuning, engine is built for 900whp, starting with only small 350whp
partlist so far
Garrett GT28rs
Wisco Pistons 86.5mm
Eagle Rods
TTE metal head gasket
ATS racing EGR block off
Apexi power fc standalone
Ko racing oil adapter for oil pan and block
Ko racing downpipe support
Ko racing reducer hose 2"-2 1/4"
Berk Ecu Adapter for power fc
GM IAT sensor
GM 3Bar map sensor
Gen3 540cc injectors
TRE 255LPH fuel pump
AEM wideband
AEM Tru-boost
Auto Gauge Oil pressure Gauge
Auto Gauge Exaust temp Gauge
Stainless Steel Exhaust manifold
Stainless Steel Downpipe for Gt28rs
Motoria 3" Exhaust
XO2 Racing 46mm wastegate
Brian Crower Valve springs
-10 AN oil return line with earls fittings
TRD 2way LSD
decided to paint the enginebay too
engine bay ready for paint
got a great shipment today
Brian crower valve springs and brian crower smell card for the exhaust :smile:
AEM Tru-Boost controller
Berk technology harness for power fc
extra wire for the power fc commander
Gm IAT sensor kit from Berk
i also sanded down the fuel filling pipe and the rain guard in the engine cover, intake manifold and intercooler pipes are ready for paint so, i has to be ready before 17th june lols
little update, intake manifold ready and bolted on, timing belt goes on tonight and i picked up the lower timing belt cover also, hope i can make my engine pretty hawt in the end
hope you enjoyed the flood of pics lols
Turbo- is offline   Reply With Quote
Old 08-27-2010, 10:03 AM   #2 (permalink)
more
i wanted the timing cover high shine black
painted the marks for the ignition in the same color as the car and valve cover and the right mark i painted white like it was before i painted it
timing belt on
ATS egr block off on
new injectors, 540cc red tops, need to move them to the old fuel rail and clean it up
installed wastegate and manifold, only need studs so i can make a t3 to t25 adapter for the gt28rs
test fitting the turbo
to much detail on stuff that will never be seen
fuel filter bracket, vacuum hardlines and manifold supports
upper timingbelt cover ready, yamaha fonts in same color as the car
prev owner had fun painting the coolant hoses and more so i sat down and rubbed them with m600(weak thinner) for about 2 hours
before :
after:
installed
well it gets closer and closer everyday, and the wallet gets thinner and thinner lols
new sparkplugs , spark plug wires, and more
test fit this weekend for the turbo adapter and downpipe location, will be installed also this weekend, woohoo long work weekend ahead
[IMG]http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs534.ash1/31336_406813613549_612643549_4260590_5074433_n.jpg[/IM
ready for test fit
fits perfectly, too much space so i think i need bigger turbo
exhaust testfitted, was better then i dared to think about, nearly perfect
looks fantastic from this angle
removed the engine again to fix more stuff
screamer pipe ready, 44mm
screamer pipe bolted on and engine ready to go into the car
engine bolted in, i gotta remove the engine mount on the driversside when the crossmember is in so i can blast it and paint it, better pics tomorrow
this is how i started this morning
all assembled except the cruise control, hoses and oil pressure sensor connection was only a quick fix to get it started
first startup, short but it started
bad idle valve, or it could be the power fc
engine bay nearly finished, needs awfull lot of cleaning now
need to fix shorten the oil line to the mechanical gauge, im running both, dont trust the electrical enough
gauges fully installed now i just need to put the radio back in
Tru-Boost - Oil Press - EGT - Wideband
Next up is water 2 air cooler and axle cages + Clutch
Old 08-27-2010, 10:23 AM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Awsome! Thats alota work.
The Jedi Speeder at CarDomain
Old 08-27-2010, 03:59 PM   #4 (permalink)
on full afterburner
Gameroom cash: $1349597
Looks like she's coming along great so far!
for taking on a project like that. I hope I get my own MKII MR2 Turbo one day.
Old 08-28-2010, 02:52 AM   #5 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1343766
iTrader Score: 7 reviews
Great pictures, that is a lot of work but it sure has paid off. I love the color, looks fantastic. I'm very jealous.
ROTM November 2011 Winner!
SuperchargedMR2 is offline   Reply With Quote
Old 08-28-2010, 03:18 AM   #6 (permalink)
Matt94MR2's Avatar
Gameroom cash: $247750
View Matt94MR2's Photo Gallery
Wow, brought that car back from the dead. Nice work!
1994 Toyota MR2 Turbo, Gen3 3S-GTE, 278 rwhp, 12.8 @ 106 mph in the 1/4 mile
1996 Toyota Corolla, 4A-FE, 5-speed
Matt94MR2 is offline   Reply With Quote
Old 08-28-2010, 09:06 AM   #7 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
Looks great. I love the color, what is it? Looks different than my nautical blue metallic. 350z blue?
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
Old 08-28-2010, 06:13 PM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Where did you get the GM(General Motors?) Map sensor?
How did you hook it up?
Old 08-29-2010, 04:21 PM   #9 (permalink)
its an old lambo anniversary color
got it from ebay, its a Omni power Gm sensor (aftermarket general motors)
used this picture and then i found the wiring diagram at www.mr2-tech.com
Old 08-29-2010, 04:37 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
^ Thanks. And you used this in place of the AFM ? right? ^
I love the color too!
Old 08-29-2010, 05:07 PM   #11 (permalink)
yeah this replaces the afm, cause i have the power fc standalone, it replaces the old pressure sensor, the sensor it self is at the wall between the trunk and engine bay where the stock sensor was
and im using the engine bay temp sensor that used to control the ic fan for a intake temp for the standalone
Old 08-29-2010, 05:10 PM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Will the GM Map sensor work without the Power FC?
Old 08-29-2010, 05:14 PM   #13 (permalink)
works with all standalones
but if you are thinking about if you can replace the afm with map sensor on stock ecu then its not possible
the gm map sensor (manifold air pressure sensor) sensor the airflow in the manifold and gives the standalone a 0-5v reading of that just as the afm gives the ecu signals before the turbo
if you unplug your afm your car wont idle or drive correctly, so if you dont want the afm you need to go standalone
Old 08-29-2010, 05:20 PM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Eh, thats what I thought. Thanks for the clarification.
Old 08-29-2010, 09:27 PM   #15 (permalink)
Russell D's Avatar
View Russell D's Photo Gallery
Looks great! You have this build on mr2.com correct?
The only way to remove the AFM is to run a standalone EMS...Not a cheap mod, but it will get the most out of everymod you have and any future mods!
FWIW, it's much easier than it would seem to run a Honda ECU on the Mr2, then you can put in a Hondata for 1/4 the cost of a AEM EMS...
-91 Mr2Turbo-363WHP/289WTQ
I'm not happy, More power coming...
Now 386hp/300tq and still not happy
-94 Toyota Pickup SR5-
Russell D is offline   Reply With Quote
Tags
3sgte rebuild, mr2 rebuild, mr2 restore
