What to do next? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2004, 02:11 AM   #1 (permalink)
View projectMR2's Photo Gallery
What to do next?
I've got a 91 3s gte with a TRD wide body and basics done (intake, exhost... etc) I want to run more boost (11psi currently) If i was to run 16psi, do i need better fuel injectors?, better ignition? And what about the heads and block, there all aluminum, can they handle it?
"sir, i didnt do anything wrong!" fixed up mr2 to the cop. "Everything you do is wrong, with your little cars. You think your fast or something?" The cop. In the back of the mr2s mind he was thinking... I run 11.9... is that still slow?
projectMR2 is offline   Reply With Quote
Old 04-09-2004, 03:36 AM   #2 (permalink)
Tearin' Up The Streets
MR2QuiK's Avatar
View MR2QuiK's Photo Gallery
not really ur stock injectors should be fine. u might want an intercooler upgrade if u want to boost safely
Depicted Motion MR2
MR2QuiK is offline   Reply With Quote
Old 04-12-2004, 01:47 AM   #3 (permalink)
What is a good but afordable kind of innercooler and where would i buy it. I buy most of my things online bc its cheaper... well atleast i think it is, bc shipping is like taxes.
Old 04-12-2004, 06:56 AM   #4 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
first off...to run higher boost...u will need a fuel cut defender and some sort of boost controller to turn up the boost....u can run 16psi max on the ct-26....a good IC upgrade would be the greddy kit......
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
