gen3 3SGTE fuel rail fit on gen2 ?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2010, 12:41 AM   #1 (permalink)
View 3SGTS's Photo Gallery
2nd Generation gen3 3SGTE fuel rail fit on gen2 ??
Does anyone know if a 3rd gen 3SGTE Fuel rail with the 540cc injectors is a direct bolt-on upgrade for a 2nd gen 3SGTE ??? thanks
3SGTS is offline   Reply With Quote
Old 09-28-2010, 10:27 AM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
I do not think they do, in every fuel rail option i find they always refer to gen 3 and gen 2 as two different rails.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 09-28-2010, 04:40 PM   #3 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Gameroom cash: $184010
View Ghostyman's Photo Gallery
The 5SFE topfeed rail is almost bolt-on (you need to make brackets by bending some aluminum stock, that's it.)
It's a lot bigger and allows you to switch to top feed injectors which are not only more common but also eliminate the pressure drop in sidefeed rails.
1989 Corolla SR5, 4A-F, 5spd, ~210k miles, 18.007s@83mph
WTB: 3sge camshafts ... PM me!
Ghostyman is offline   Reply With Quote
The Following User Says Thank You to Ghostyman For This Useful Post:
MR2Jedi (09-28-2010)
Old 09-28-2010, 05:13 PM   #4 (permalink)
What top feed injectors with decent flow capacity (540cc +) are common and/or not super expensive?
i have a Sard FPR i havent installed yet and a stock Celica All-Trac fuel pump
Old 09-28-2010, 06:20 PM   #5 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
RX7 injectors are 750cc if I recall correctly. Pretty cheap.
You can can do a simple mod to some Subaru injectors to make them 800cc+ (see http://www.witchhunter.com/subarumod1.php4 for a reputable description).
In my opinion, there's no good reason to stay with side-feed injectors if you are touching your fuel system.
(Side note: the 5SFE rail flows probably four times the volume of the 3SGTE rail. It's that much bigger)
Old 09-28-2010, 09:45 PM   #6 (permalink)
Russell D's Avatar
View Russell D's Photo Gallery
You can also get SupraTT injectors, they are 550cc, will drop into the gen2 rail, the plugs will fit with no mods and the ecu can control that injector
-91 Mr2Turbo-363WHP/289WTQ
I'm not happy, More power coming...
Now 386hp/300tq and still not happy
-94 Toyota Pickup SR5-
Russell D is offline   Reply With Quote
Old 09-28-2010, 10:35 PM   #7 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
I guess at this point we really need to know what mods and engine management 3SGTS has.
Old 09-29-2010, 12:32 AM   #8 (permalink)
92 usdm 3sgte ecu, precision 750 fmic, 3" exh from turbo back, 3SGE intake manifold, ferrea valves & retainers, hks springs, tvis deleted, p & p, t3/t4 46trim for now, turbonetics wg with 15lb spring, Sard fuel pressure regulator
this car's my daily driver so what i want is a fast enjoyable street car on 93octane
hp goals 350 ~ 450 range
i know someone that has a 3rd gen fuel rail w the 540cc inj
i'm thinking this should give my engine a boost in power from the 440cc i have now
let me know what u guys think
Old 09-30-2010, 10:53 PM   #9 (permalink)
Russell D's Avatar
When you say 'p&p' are you talking about an ems system? If not you need one, or at least an ATS chip
Are you power goal BHP or WHP? And that is a very wide power goal, building a 350whp mr2 costs probably half as much as building a 450whp mr2...
If you are even considering making more than 350whp you will need bigger injectors than the 540cc, and if you need bigger injectors than that you need a different ecu...
Are you running a front mount IC? if so, at least move that to the trunk
Old 10-01-2010, 12:26 AM   #10 (permalink)
p&p is my short way of writing Port & Polish,
Yeah, after i wrote that reply i realized that's really broad. for now because of finances im looking for right around 350 whp
I actually have a Celica but I posted the thread here because more of you MR2 guys know my engine better than at the Celica forum. when i talk about 3sgte over there i barely get a response. Fmic is perfect for my setup.
Old 10-01-2010, 12:46 AM   #11 (permalink)
Ghostlyman, I just got a gen1 3SGE fuel rail that i can install on my gen2 3sgte. It's a top feed rail which I'm putting my 7MGTE 440cc injectors on (low imp just like 3s). I know the cc's are the same but who cares. My question for you is how does the 3sge vs 5sfe fuel rail compare? 3sge uses 295cc inj vs the 5sfe 220cc iirc so maybe that could be a clue ... idk
oh and what fuel pressure psi would you think is optimal?
I know i need to tune, people, i def am aware of that. at the moment i'm trying to get the right parts in place a step at a time. thanks for all the feedback i appreciate it
Old 11-05-2010, 11:08 PM   #12 (permalink)
2nd Generation
I got a 5SFE fuel rail finally and that thing looks monster ! Ghostyman if you have any pics of how you made your brackets could you please post them? Also the 3sgte head has injector ports that are sized specifically for the side-feed 440cc injectors that come stock, when i put top feed injectors on the head they sit noticeably loose. How did you go about to fit them tight? thanks,
Alex
93 Celica GTS 3SGTE
91 Supra Turbo 2JZGE-T
Old 11-06-2010, 04:06 PM   #13 (permalink)
Homer Lusk Collyer
Ghostyman's Avatar
Alex
I'll get you some info on the brackets in a bit... I don't have the brackets made for mine yet but I've got the specs somewhere. Bolt spacing is the same so it's just a piece of aluminum with two right angle bends in it.
Thanks for mentioning the injector not fitting the head because I'd forgotten about that part. You'll need to cut the bases off the 3SGTE fuel rail and use them as adapters for the 5SFE rail. I'll post pics of mine once I dig them out of my garage.
Old 03-11-2011, 06:42 PM   #14 (permalink)
This is a confirmation that 2nd and 3rd gen 3sgte fuel rails are NOT interchangeable!
The bolt holes to secure the rail to the head are very different
What can be interchanged are the injectors and the fuel pressure regulator, decent upgrade for 2nd gen owners but the engine will run like CRAP if you don't tune it somehow with an emanage or at least a SAFC (be careful though) and a wideband oxygen sensor for sure. you should only go bigger injectors with the stock ECU if your setup is noticeably modified; bigger turbo, full 3" exhaust, cat delete, tvis delete, better intercooler, port+polish, bigger cams, etc
hope this info helps
93 Celica GTS 3SGTE
Old 08-13-2011, 10:47 AM   #15 (permalink)
View mikealike's Photo Gallery
other than the mounting tabs is the distance from injector to injector the same? it seems like that in the pic.
mikealike is offline   Reply With Quote
Tags
3sgte fuel rail, 5sfe fuel rail, 750cc injectors, 800cc injectors, fuel rail, rx7 injectors, sard injectors
