SERIOUS PROBLEM! Have no Clue whats wrong! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2004, 07:57 PM   #1 (permalink)
View IMPORTMyth01's Photo Gallery
Ok heres the deal...I just bought a 3 inch down pipe and I go to install it and everything checks out o.k. I broke some studs but after some WD40 and a welder they were easily removed. Everything checks out fine, I wired up the new 4 wire Bosch O2 sensor and was ready to try it out....NOT! I go to start the car and on the ON Key position the car tries to start!! I didn't even push the clutch in! I dont get it...so we brought out the scanner and the wiring diagrams to see if one of the wires were crossed or if one of the wires grounded out...everything seemed o.k. as for connections, but we found one complication...If we disconnect the Cold start clip the car wont try to start in the ON position but will crank over when you try to start as normal...but it still doesnt start!!???!! Dont get it I rolled up to get an exhaust upgrade and end up leaving my car at the shop after fighting with it for 12 hours!
Anyway just out of curiosity, do ECU's go out at all? If so could the welding have done it (I have welded on the body and frame many of times though).
What about the cold start injector? Would I have seen any previous signs of shorage or malfunction??
Thanks Ray
Surgeon General says its o.k to smoke v8s
IMPORTMyth01 is offline   Reply With Quote
Old 04-14-2004, 12:28 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
i dont think its ur cold start injector....i completely removed mine and never experienced any problems....if ur ECU goes...the car won't even start at all.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 04-14-2004, 08:20 PM   #3 (permalink)
View mr2freak's Photo Gallery
thats a fact
to answer your question
if you used a mig, you might have fucked the ecu
if you used a torch, then naw, ecu should be fine, so its somethign else
Women... can't live with 'em, can't shoot 'em - 87camry5speed
Seriously... PETA is a militant group. They suck in genuinely concerned people, and spit out hitler faeries - Toysrme
mr2freak is offline   Reply With Quote
Old 04-14-2004, 10:55 PM   #4 (permalink)
found out what problem was today...somehow the new O2 sensor wasn't grounding it self good enough, in turn sent out resisting voltage throughout the ECU, resulting in all kinds of wiring problems. So I just tapped into it and made a steady ground Thanks
