engine specs needed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2010, 01:02 AM   #1 (permalink)
N/A bites
Tercel GTS's Avatar
engine specs needed
Anybody have straight info on 3sgte and 5sfe specs? Looking for rod length, journal diameters, bore diameters and pin to piston top measurements. Playing with the numbers I'm looking to build a near square 5sgte. Also does anybody know how far you can bore a 98^ block without major temp problems?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 10-10-2010, 08:45 AM   #2 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
http://www.megaboost.co.uk/mr2/frames/techinfopage.htm
enjoy
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 10-10-2010, 01:11 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Bore which block?
My 3sgte is bored .040 over. No problems whatsoever.
The Jedi Speeder at CarDomain
Old 10-10-2010, 05:42 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
3sgte
Crankshaft Main Journal Diameter Service Spec..54.988-55.003mm 2.1653-2.1655in.
Camshaft Journal Diameter service Spec..26.959-26.975mm 1.0614-1.0620in
Bore Diameter.. 86mm 3.3858in
5sfe
Cam Journal Diameter service spec...same as 3sgte
Crankshaft Main Journal service spec..same as 3sgte
Bore Diameter...87mm 3.4252in
5sfe rod journals are larger than the 3sgte, but I don't know the diameters.
MR2 guys build strokers using the 5sfe block and crank, having to turn the crank rod journals to accept the 3sgte rods.
Hope this helps.
