Well the 1ZZ doesn't use a timing belt, it uses a timing chain. However, the water pump (and all other accessories) is driven by a serpentine belt, IIRC.
More than likely the engine has warped and the head gasket blew. Aluminum blocks don't take kindly to being overheated. The fact that it will no longer start probably means you lost compression in 2 or more cylinders. The engine could limp on 3 cylinders, but not 2.
BTW, Toyota ECUs initiate timing retard above about 220*F, so that explains your loss of power under load as it was likely already overheating. At idle, the ECU will move to advanced timing (to raise the idle and improve coolant flow), which can cause the engine to stall. At roughly 240*F, maximum timing retard is used under load and maximum timing advance at idle.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
