Steps for radiator flush on an mr2? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2010, 09:34 PM   #1 (permalink)
View tidus21's Photo Gallery
Alright I know that these are the normal steps.
1. Let Engine Cool
2. Remove Radiator Cap
3. Remove Radiator Plug and Empty
4. Flush Radiator with water until the water looks clear
5. Empty Overflow container and put Radiator Plug back in
6. Refill the radiator through the cap with 50/50 and some in to the overflow container
7. Start up car
Now On some places they suggested removing the "Air plugs" which I have no clue what that is and secondly am I missing anything?
tidus21 is offline   Reply With Quote
Old 11-04-2010, 08:15 AM   #2 (permalink)
View mnkibler's Photo Gallery
Which MR2 are you talking about? That would help.
Two 2003 MR2 Spyders, 2003 Highlander, 2003 CR-V, 2008 Tacoma
mnkibler is offline   Reply With Quote
Old 11-04-2010, 11:44 AM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
He's got a 2nd gen, but the process is basically the same for all gens.
Bleeding the system of air is crucial, or you'll have over heating problems and/or possibly no heat from your heater.
There is an air **** on the top driverside of the radiator. With engine running, open this valve and this will release the air trapped at the top of radiator reservoir.
There is another valve on the heater core. Use the same procedure to evacuate the air from there.
It's a long long process of bleed and add coolant, then bleed and add coolant, over and over untill system is free of air.
Raising the back end of the car can help speed this process up.
The Jedi Speeder at CarDomain
