help installing the msd 6a - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2010, 09:57 AM   #1 (permalink)
THEARCHITEK's Avatar
View THEARCHITEK's Photo Gallery
so i bought an msd 6a and dont know how to install this,
i know i dont need the green and violet plug,
so the big red and big black to the battery,
the small red to ignition, where exactly do i hook this up to the relay on the engine compartment??,
also the white cable goes where the white cable is at, at the plug on the distributor???
and im not using the blaster so i guess the orange and small black cable is needed
thanks
THEARCHITEK is offline   Reply With Quote
Old 11-07-2010, 10:12 AM   #2 (permalink)
30 yrs of Car Photography
hairball's Avatar
View hairball's Photo Gallery
Is there a part number on your unit? I mean the MSD unit!
Like maybe a 4 digit number? Didn't it come with instructions?
By the way, "Hairball" was a cat of mine.
Since I don't use the "GameRoom", can you just send me a check?
hairball is offline   Reply With Quote
Old 11-07-2010, 10:14 AM   #3 (permalink)
nah i bought on the street but ill look at it and tell you in a few mins, i really want to hook this up, it should have a like 6200 or something if thats what your talking bout
Old 11-07-2010, 10:26 AM   #4 (permalink)
it is 6200
Old 11-07-2010, 10:34 AM   #5 (permalink)
hairball's Avatar
RED: Ignition Switch
WHITE: Distributor
BLACK: Coil negative
ORANGE: Coil positive
GREY: Tach output
HEAVY RED: Battery positive
HEAVY BLACK: Battery negative
Old 11-07-2010, 10:35 AM   #6 (permalink)
sorry bought this dumb question, so the white cable goes to the white in the distributor, correct? im a noob when it comes to this type of stuff so
Old 11-07-2010, 10:41 AM   #7 (permalink)
hairball's Avatar
Is your car a 93 Corolla as in your link? This pic looks like a Celica Supra. Do you have 4-cylinder or V-6?
Old 11-07-2010, 10:43 AM   #8 (permalink)
is an toyota mr2 a 92 and is 4cyl
Old 11-07-2010, 11:00 AM   #9 (permalink)
Old 11-07-2010, 11:07 AM   #10 (permalink)
hairball's Avatar
That would be my guess but I'm not looking at a diagram so I'm not really sure what color your distributor wires are. Do you have a white wire?
Someone else here will probably have to answer this question because I'm not sure about which wire to hook it to on a Toyota.
Old 11-07-2010, 11:15 AM   #11 (permalink)
hairball's Avatar
oh wait... do you have 3 wires from your distributor? White, Black, & Red? If so, YES the white MSD wire goes to that white dist wire.
Crankshaft Position signal goes through the red dist wire.
RPM Signal goes through the white dist wire.
But I'd wait for someone else here to confirm all this before you try it. The last thing you want to do is fry something.
Old 11-07-2010, 11:16 AM   #12 (permalink)
hairball's Avatar
Sorry... I was doing some checking. Didn't forget about ya.
Old 11-07-2010, 11:23 AM   #13 (permalink)
yeah true, i was thinking bout this it kind of makes sense but i dont wanna mess something up, i just need to know where too put the white wire at, and yeah i have those same 3 cables u mention
Old 11-07-2010, 11:28 AM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I think the MR2 turbo has 4 wires to the dizzy.
The Jedi Speeder at CarDomain
Old 11-07-2010, 11:29 AM   #15 (permalink)
nah only 3
Tags
5sfe msd, coil, coil diagram, n/a mr2 msd
