Hello Everyone - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2010, 07:04 AM   #1 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
Hello Everyone
Been a while since i have been back on here. Figured i would give alittle update on my car. For anyone that remembers me this is the car i have been working on for the past 3 years now and am finally getting it done. Here is a pic of the car
and here is a pic of the engine installed about 3 months ago
and now the story....
Well i had it "running" or at least i thought. (this is a fully built motor, the works) We ran it around the block a few times. It seemed fine. Checked temps, all that good stuff. Then dumped the oil again. Ran it some more, all seemed good. So i figured its time to finally give this a drive. Well about 10 miles into the drive i pull over and the car shuts off, oil all over the ground.
So now i tow it back and its times to resolve this. (mind you this has been a long time coming to drive so i am pissed to say the least). We check it over and find ZERO compression....not good. So at this point it has been three of my friends and i doing all the work on the car, i figure its time i got someone working on this car that really knows an MR2. So i had it towed to his garage. His findings are below.
First thing he noticed is that the headgasket is in fact UPSIDEDOWN!!! This caused the oil feed port to the head to be blocked, therefore the head got absolutely NO oil. Notice in the picture below that the arrow on the bottomside of the headgasket in the upper right corner of the picture, should be pointing the other way
now then, he went and removed the head and he said there appeared to be no damage (which was confirmed by a machine shop) and then noticed that 2 of the pistons appeared to be backwards. Notice in the picture below that the valve reliefs of 2 and 3 are 180 degrees
after this is was onto the block. He then realized that the motor would not turn by hand (it was seized) so something major was wrong. He took the oil pan off and first found that the main caps were all pointing the right way however instead of going 1-2-3-4-5 they were going 5-4-3-2-1. See below
and now onto the final big mistake. I had numerous problems getting the correct bearings for this car. We had to exchange the main bearing 3 times and the rod bearings once. Well i guess we should have exchanged the rod bearings one more time because they were what seized the block. Here is a picture of what the rod bearings looked like. Now i must stress this is only 10 miles of wear on them
So now my engine is being redone by a machine shop (lesson learned there) and there appears to be no major damage. Which is very lucky considering what could have happened to this. All of my internals are good (pistons, rods, crank) the head and cams are good, all it will cost me is some new bearings, machine shop work, gaskets, and labor. All in all i may finally get a running car after this.
Hope you enjoyed the story, haha. Please retain from tons of flaming on this. We screwed up on this engine. We have worked on other cars before but this was the first attempt on the 3sgte and there were alot of things that we had never seen before like a headgasket that is able to be installed upside down. Or pistons which different valve reliefs.
Anyway its been a while since i have been on here, i'll be posting around again.
TheEngineer is offline   Reply With Quote
Old 11-23-2010, 09:30 AM   #2 (permalink)
on full afterburner
Gameroom cash: $1349297
Very nice!
Good to hear that it's finally all coming together!
Old 11-23-2010, 10:30 AM   #3 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
damn! sorry for all of your troubles! did you use a BGB when you did your assembly? glad you learned from this experience!
on a side note: are you an engineer?
1/2 a tank of V-Power gas+ 1/2 tankful of fuel with Techroline= V-Tec gas??? Speed and grip walk a very thin line of balance. If a car feels like it's on rails, then you're probably not going fast enough.
ToyotaTechGeek is offline   Reply With Quote
Old 11-23-2010, 12:14 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
OK, no flames, but Wow!
You really did get lucky that there wasn't any more damage than that.
You plan on a dyno run? What turbo and cams are you running?
Good to have you back!
The Jedi Speeder at CarDomain
Old 11-23-2010, 05:50 PM   #5 (permalink)
yea a Civil Engineer
MR2Jedi,
Yea id say i was pretty lucky. I am planning on around 380whp on it. I am only running a 46 trim turbo with GSC 268 cams
Old 11-23-2010, 10:15 PM   #6 (permalink)
Russell D's Avatar
View Russell D's Photo Gallery
Looks good minus the engine part, but since there is no damage to any of the internals it's nothing to worry about!
At least you know everything will be done right now. I was very nervous when I assembled the engine I built for my mr2, but I took my time(I spent 2 days assembling the engine) and I didn't do anything without memorizing the BGB. The only thing I was unsure about with my engine was bearing sizing, but I've got over 2K on my motor and it build good pressure and there is no visible wear; but once I get the new head done I am going to be swapping those so then I will be able to get a good look at the piston walls...
Nice build though! I don't know if you will quite hit your HP goals with that turbo and a sidemount IC; I made 363whp with a 57trim t3t4 and my intake temps were ~145deg with my apexi sidemount!
-91 Mr2Turbo-363WHP/289WTQ
I'm not happy, More power coming...
Now 386hp/300tq and still not happy
-94 Toyota Pickup SR5-
Russell D is offline   Reply With Quote
Old 12-08-2010, 01:44 AM   #7 (permalink)
View EMSPowered's Photo Gallery
Looking great!
EMSPowered is offline   Reply With Quote
Old 12-09-2010, 02:05 PM   #8 (permalink)
small update
here is where the engine now sits at the shop its being worked on. Close to being ready for install
Old 12-09-2010, 04:57 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Purdy!
Old 12-10-2010, 07:32 PM   #10 (permalink)
Originally Posted by mr2jedi View Post
purdy!
+1
Old 12-24-2010, 04:02 PM   #11 (permalink)
getting there
Old 03-02-2011, 08:15 PM   #12 (permalink)
ITS ALIVE....
Finally got this thing running. We were playing around with the AEM tune a bit yesterday. Trying to get it dialed in enough for engine break in before i dyno tune. Still got some kinks to work out but i never thought this day would come. Here is some pics.
Engine in (hopefully it never has to come out again, haha)
Proof that its running
Old 03-02-2011, 08:43 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Wow! Congrats!
You build that intake manifold yourself? Looks massive!
You have an estimate of what you think the HP/TQ #'s will be?
Old 03-02-2011, 10:59 PM   #14 (permalink)
nah the intake manifold is an RMR. It is amazing quality and size. No bottleneck there, haha.
Right now im probably only gonna be around 375whp just because of the turbo and the intercooler. But if i were to upgrade those two things alone the system is good for around 450whp
Old 03-02-2011, 11:45 PM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
375 HP is nothing to scoff at!
That'll pull the 2's 2800lbs like mad!
Nice job.Looking good!
