1992 MR2 Bad miss no power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2010, 04:10 PM   #1 (permalink)
View kennywayne99's Photo Gallery
I have a 92 MR2 that has slowly developed a bad miss.When accelerating it misses bad and has no power.It jerks and misses really bad almost like its gagging.It had a really rough idle to so I thought I would try something easy and put a set of plugs in it .So I did that and it still has no power when driving. Now it idles super fast at about 2300 rpm's.It will idle at about 2300 then it s will drop to about 1800 rpms just for a second ,almost like its getting choked off and then right back up to 2300.Anyone have any suggestions what it could be.I was gonna try the fuel filter(which I don't think it is) next and then maybe the TPS.I also did a diagnostic code check where you use the paper clip and jump the leads and there were no codes stored.
Thanks for your help.
kennywayne99 is offline   Reply With Quote
Old 12-28-2010, 08:01 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Turbo or N/A ?
The Jedi Speeder at CarDomain
Old 12-29-2010, 09:47 PM   #3 (permalink)
No it's not turbo
Old 12-30-2010, 11:25 AM   #4 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
There is only three things as we know that gives you combustion in an engine. Air, Spark, Fuel. Check those basic things first. Make sure your wires are not bad, damaged wires that bounce around can cause spark to be lost intermittently.
While you may not think so, I have heard of fuel filters causing very similar problems to what yours is doing. Seeing as the fuel filter costs under $20 and is very easy to install, I think it would be to your benefit to try it anyway. That is unless you have already done one in the recent past.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 12-30-2010, 07:36 PM   #5 (permalink)
Where exactly is the fuel filter?Is it very hard to get to?I looked around but could not find it.I ordered a fuel filter and it should be here tomorrow.
Thanks
Old 12-30-2010, 07:51 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
You can access it from underneath, on the drivers side, mounted to the chassis in front of the transmission.
Old 12-31-2010, 10:41 AM   #7 (permalink)
Gameroom cash: $107200
View TheEngineer's Photo Gallery
spark plug wires
TheEngineer is offline   Reply With Quote
Old 01-01-2011, 03:28 PM   #8 (permalink)
Worked on car today and was pulling plug wires off and checking them while it was running and noticed two of the plug wires were arcing through the plug boot stem down inside the valve cover near the plug causing it to misfire.I put those wires on a couple years ago and they were fairly expensive American made wires,I was surprised they were bad.I still had the original set I had saved and put them back on and it runs really good now.
Thanks to all who helped.
