Originally Posted by forumboarder154
Thanks Jedi. PM sent. I appreciate it man. Also I love your car it is putting down good numbers. I am new to this MR2 and just trying to get things figured out. I usually fool around DSM's, but I really love this MR2. I think I might have possibly bled it wrong also. Would air in the system cause higher pressure in the coolant system and cause it to leak?
If you've got air in the system, it can cause overheating and then higher pressure.
There are several threads on the bleeding proceedure here. It's not that bad, just have to repeat steps over and over to get out all the air.
It's important to bleed the radiator via the air **** on the top driverside and thru the valve on the heater hose in the front trunk(frunk).
It also helps to jack up the rear of the car to send the coolant forward to the radiator.
